Sprockets Help
Has thanked: 12605 times
Sprockets Help
Some teeth here are a bit naff. Can I just replace the biggest sprocket?
Or do I need to buy the whole thing?
And where do I go to get them?
I know fark all about bikes.
Has thanked: 1926 times
Been thanked: 1728 times
Re: Sprockets Help
You can just replace the large chain ring. But you will need a crank extractor to access the mounting bolts (in some cases you can do it in situ).
But if you chain ring is worn, and you just replace that, you may find the chain jumping all over the place , especially under load.
You might find that you have to replace the cassette and the chain at the same time.
Why do you think the chain ring needs replacing?
Ditchfinder
Has thanked: 861 times
Been thanked: 1069 times
Re: Sprockets Help
Post by Ditchfinder »
All the cool kids have ditched 3 front rings, shifter and mech for 1 chainring up front and a wide range rear cassette.
What does the bike get used for?
Re: Sprockets Help
Ditchfinder wrote: Tue Feb 18, 2025 2:24 pm All the cool kids have ditched 3 front rings, shifter and mech for 1 chainring up front and a wide range rear cassette.
Usual route is 10 miles. Only 2 miles on gentle dirt paths.
It's got a few other problems and thinking of ditching it and spending 500€ - 750€ at Decathlon.
Are these old bikes worth chucking money at?
Ditchfinder
Re: Sprockets Help
Depends how much you need to chuck at it. Is it a 9 or 10 speed rear shifter?
Re: Sprockets Help
Ditchfinder wrote: Tue Feb 18, 2025 2:33 pm Depends how much you need to chuck at it. Is it a 9 or 10 speed rear shifter?
7
Ditchfinder
Re: Sprockets Help
Really? that model of rear mech looks way newer than 7 speed!
Ditchfinder
Re: Sprockets Help
Pretty sure it's an rd m772 which is 9 speed. You can fit an 11- 40t cassette (I use ZTTO ones) to that. Change the front middle ring to a 32t (104 BCD) and discard the others. Ditch the front shifter. Throw a new chain on as you will need to shorten it anyway. Should be less than £100 easily.
You should just about be able to take the middle ring off which the chainset in situ on that chainset. Might have to remove the pedal though.
If you're not racing or winching up the sides of a mountain you will have plenty of range.
Re: Sprockets Help
Ditchfinder wrote: Tue Feb 18, 2025 2:35 pm Really? that model of rear mech looks way newer than 7 speed!
Oops. It's 9 :obscene-birdiedoublered:
Ditchfinder
Re: Sprockets Help
Re: Sprockets Help
Ditchfinder
Re: Sprockets Help
weeksy wrote: Tue Feb 18, 2025 3:14 pm
Lol I can't wait for this 🤣
Care to expand...... :1
(the 2nd link should be to a chainring but it seems to default to the chainring bolts :roll: )
Re: Sprockets Help
I won't be attempting anything technical :D
Will need local shop to sort it. And with rear shock rebuild and a few other little jobs, gonna be around 300€
Reckon it's time to give in and buy summat else.
Ditchfinder
Re: Sprockets Help
:banana-wrench: All you need is a chain splitter and a 5mm allen key
Ditchfinder
Re: Sprockets Help
:oops: I tell a lie the old cassette needs to come off too doesn't it
Re: Sprockets Help
Yorick wrote: Tue Feb 18, 2025 3:19 pm
In truth, that bike has had it's day and i know it has a bit of nostalgia for you, but yeah really it's had a good innings.
Do cover any metal on the new bike in ACF50 though to see if you can keep the ravages of salt water at bay.
and CLEAN the chain ;) just a bit of GT-85 is a good start :)
Re: Sprockets Help
I may have been right. I'm sure I counted 7 when I bought it.
But when I had to change the set, I just bought whichever Shimano set that Decathlon had in.
But I just checked the sets on the spare wheel I got.
One is 7, one is 9.
Looks like the original Shimano was 7. Who knows ? :obscene-birdiedoublered:
Ditchfinder
Re: Sprockets Help
Orange 5's were never sold new with a 7 spd freewheel and that rear mech would only work with a 9 spd cassette :wtf:
Or for that matter a bolted hub :lol:
Has thanked: 2556 times
Been thanked: 4167 times
Re: Sprockets Help
Yorick wrote: Thu Feb 20, 2025 4:20 pm 20250220_161319.jpg20250220_161555.jpg
Do you leave it in the ocean when it's not in use?
