The F350 Thread
Has thanked: 2288 times
Been thanked: 2673 times
Re: The F350 Thread
Got the rear wheels pulled, dismounted inner tires, swapped out schraeders for longer ones, balance & remount tires. Now I can check the inner tire pressure in a mere moment instead of 20 minutes of faffery.
Re: The F350 Thread
Didn't fancy fitting a TPMS while you were in there?
They're a legal requirement on new cars over here. S'great really, I can just say "Guten tag Frau auto, what are the tyre pressures?" and she tells me.
Re: The F350 Thread
Mr. Dazzle wrote: Sat Feb 01, 2025 11:03 am Didn't fancy fitting a TPMS while you were in there?
One more potential failure point...
Re: The F350 Thread
If it fails you just go back to checking manually, it's not like they let your tyres down.
Bosch make literally millions of the things, they're cheap and reliable.
Re: The F350 Thread
Mr. Dazzle wrote: Sun Feb 02, 2025 9:29 am If it fails you just go back to checking manually, it's not like they let your tyres down.
I'm retired, pretty sure I can spare the time.
Re: The F350 Thread
Looks like I'm going on an 1800 mile road trip in August...
https://www.nobstruckshow.com/
It's at this place... 14 museums..
https://www.antiquepowerland.com/
Has thanked: 8035 times
Been thanked: 5693 times
Re: The F350 Thread
ZRX61 wrote: Sun Feb 02, 2025 3:49 pm Looks like I'm going on an 1800 mile road trip in August...
They missed the 'k' off the first web address. :lol:
Re: The F350 Thread
Count Steer wrote: Sun Feb 02, 2025 6:35 pm They missed the 'k' off the first web address. :lol:
LMFAO!!!
Re: The F350 Thread
New Hella 450 spots fitted, work of a moment. Still need to wire them up & adjust. Ordering the yellow fogs is next.
Re: The F350 Thread
WooT! Some chap offered to buy the old lights. He has 5 or 6 trucks like mine.
Re: The F350 Thread
Old lights sold & shipped off today. Was going to throw them away, but he offered a pittance & I accepted.
All four of the new blinders installed, just need to hook up the harness.
Re: The F350 Thread
Got stuck in doing the harness for the lights. There are three wires coming through the grill behind the lights.... and they connect to EIGHT wires on the lights so lots of bullet connectors. One of three wires is a common ground, so that got connected the ground on each light via a pair of 2:1 connectors (left pair & right pair), the second of the three was power to the outer pair & the third was the power to the inner pair (which used a 3rd 2:1). There was already a 1:2 for the power to the outers which got reused.
AND!! It all fucking worked right off the bat WooT! :)
I'm not sure I could even draw up a wiring diagram for it. At least all the ground wires are black, power to the outers goes from purple to blue & power to the inners goes from yellow to blue. FFS
Re: The F350 Thread
New corner brackets (2) showed up the tonneau cover. Front left one on the truck was broken. Swapping it out turned into a bigger ballache than expected, but sorted now... so two of my F clamps are now back in the garage.
Re: The F350 Thread
Checked the new lights out in the dark....KEErist, they're bright :)
Re: The F350 Thread
Dropped by the local carpet/flooring shop. $20 remnant is now a fitted carpet in the truck bed :)
Has thanked: 3003 times
Been thanked: 2522 times
Re: The F350 Thread
I thought the whole idea of a pick up was that you could load a pile of shit in the back, take it wherever, unload it and hose out the bed.
Carpet does not compute.
Has thanked: 10959 times
Been thanked: 3995 times
Re: The F350 Thread
Cousin Jack wrote: Sat Feb 15, 2025 10:00 pm I thought the whole idea of a pick up was that you could load a pile of shit in the back, take it wherever, unload it and hose out the bed.
He doesn't want to scratch the diamond checkerplate.
Re: The F350 Thread
Truck isn't insured for that *work* kinda malarky, but the carpet is loosely fitted so I can just roll it up & remove it. I may end up sleeping back there at the Lake Havasu show in April. I can easily remove the spiffiness, load the bed & hose it out etc. In fact it will get hosed out before the Havasu run as the bed liner is looking kinda dusty.
Rockburner wrote: Sat Feb 15, 2025 11:24 pm He doesn't want to scratch the diamond checkerplate.
There's only 4sq ft of diamond plate back there. It's to protect the end 4x8 sheet of varnished plywood at the tailgate end.
In other news: I did some paint correction on the top of the rear fenders & a couple of other spots today. Removed a ton of those fine angel hair looking hazy scratches that show up in bright sunlight. Rather pleased with the result. When I have more time I'll do the bonnet too.
Re: The F350 Thread
Adjusted the front wheel bearings on the F350 today after noticing a bit of play when I had it jacked up yesterday. Used the Land Rover/P51 method & got it all sorted... after some frustration trying to get the fucking dust caps off.
They're kind inside the assembly so couldn't pry or use channel locks etc. Eventually succeeded by using a drum brake adjust doodad that looks like a small pry-bar. Getting that sorted took longer than adjusting the bearings & getting it all back together.
So that just saved about $500 at the shop. ("The Shop" being the name of the local diesel experts place)
Re: The F350 Thread
Mulholland on Feb 16th.
Mountain from MASH opening credit above the cab in the last pic.
