Weather Station.
- MingtheMerciless
- Has thanked: 3644 times
- Been thanked: 2502 times
Weather Station.
My old Davis Instruments Vantage Pro finally died last year after 20 years of service, I was debating about replacing it as they are not cheap but Mrs M said she would make a contribution (birthday sorted) so a Vantage Pro 2 with Solar and UV sensors and fan assisted cooling temperature sensor arrived. I managed to install the weather station today, the anemometer goes up tomorrow, wind allowing.
Things have come on a bit since my old weather station with an easy web access to the data.
https://www.weatherlink.com/bulletin/15 ... e612e17d7a
- Mr Moofo
- Has thanked: 1926 times
- Been thanked: 1728 times
Re: Weather Station.
TBF , I just use the Davis app and access free information from Worthing Pier/ BHAFC trains ground? Shoreham NCIMingtheMerciless wrote: Thu Jan 23, 2025 5:47 pm My old Davis Instruments Vantage Pro finally died last year after 20 years of service, I was debating about replacing it as they are not cheap but Mrs M said she would make a contribution (birthday sorted) so a Vantage Pro 2 with Solar and UV sensors and fan assisted cooling temperature sensor arrived. I managed to install the weather station today, the anemometer goes up tomorrow, wind allowing.
- Has thanked: 8039 times
- Been thanked: 5694 times
- Mr Moofo
If it makes you feel better, we don't even have on that the RNLI. We use the link from the NCI!
I have a pebble suspended on string.Mr Moofo wrote: Thu Jan 23, 2025 8:06 pmIf it makes you feel better, we don't even have on that the RNLI. We use the link from the NCI!
If it's white - snow
If it's wet - rain
If it's off vertical - wind
If it moves a lot - blustery wind (or earthquake)
- ChrisW
- Has thanked: 3714 times
- Been thanked: 3027 times
Nice upgrade! That web access is a huge step up. 20 years of use is impressive, though, it was time.
