Shadow foam toolbox/case
Sunny
Has thanked: 957 times
Been thanked: 519 times
Re: Shadow foam toolbox/case
Post by Sunny »
Cheers both!
Has thanked: 143 times
Been thanked: 497 times
Post by Silly Car »
weeksy wrote: Fri Apr 19, 2024 8:01 am Needs some of this
Would now be an appropriate time to mention I can currently get 20% off Wera tools at Screwfix via the mobile app? :D
Ends 30/4/24 at 23.55
Has thanked: 5449 times
Been thanked: 13084 times
Completed now.
Layers 2 and 3
ImageIMG_20240428_090901 by Steve Weeks, on Flickr
ImageIMG_20240428_090846 by Steve Weeks, on Flickr
Just waiting for the sticky glue stuff on lid layer to cure.
Right then, minor question time.
If you look at the pic and in particular the lid, it goes just past 90deg on this pic. That is now about another 15deg further as the hinge at the back is a little on the cheap/weak side of things. The back of the hinge with the weight is moving away from it's housing and either flexing/bending a bit.
So what i need is 'something' to keep the lid closer to 90deg and not letting it extend past that point. There's no current 'fixing' points i can use but i'm happy to drill/rivet something in place.
I think it just needs something like these corner pieces on this table
https://www.ebay.co.uk/itm/284867970540 ... dZA&edge=1
That'd do the job nicely and stop it going past where we want it.
Longer term i'll likely re-design the whole lot anyway and get a higher quality case to put it all in. This really was designed and bought as a test project and in truth has been brilliant. But it's cheap and cheerful rather than a long term solution.
Has thanked: 599 times
Been thanked: 2428 times
A bit of webbing riveted on one / both corners would do the job
MrLongbeard wrote: Thu Jul 25, 2024 10:04 am A bit of webbing riveted on one / both corners would do the job
Yeah i was thinking just a little bit of chain with rivets both ends. It may even be cool to use bicycle chain as it will kinda fit in with the whole ethos of MTBing.
https://www.penn-elcom.com/200mm-chrome ... ioQAvD_BwE
What do you reckon ? I'm not very good at visualising how things will open/lock.
edit.
https://www.penn-elcom.com/130mm-nickel ... 6EQAvD_BwE
They could be the ones i want.
Bought a couple of these. @crust has a rivet gun we can use.
Been thanked: 2612 times
Pelicases used to be well made and waterproof too if that matters.
cheb wrote: Thu Jul 25, 2024 11:40 am Pelicases used to be well made and waterproof too if that matters.
Well made yes, waterproof not so much.
The case i have is OK but you can see it's on the cheap and cheerful side of things. So at some stage it'll get swapped for a better one.
Would the modular boxen made by Dewalt, Makita etc do the job?
cheb wrote: Thu Jul 25, 2024 11:53 am Would the modular boxen made by Dewalt, Makita etc do the job?
Depends on size really. The box i have is about 450/330/140 and it's about the right size to carry most things in there. I could arguably go bigger and still have some tools not fitted.
ImageIMG_20240728_082104 by steveweeks59, on Flickr
ImageIMG_20240728_082111 by steveweeks59, on Flickr
ImageIMG_20240728_084936 by steveweeks59, on Flickr
In truth, it's a bit past it's best. It was cheap and cheap for a reason.
Time to revisit this thread as it's winter and i found what i needed/thought wasn't necessarily what ended up being the correct/most used. So over winter i'm going to re-do all of this and see what we can come up with this time.
I've emailed Redbox again to see if they can laser/CNC etc a custom set as i'd like it doing nicely rather than what i've managed between me and the wife.
We found some tools/additions over the course of the season
Please see your pricing as follows.
One off scan and set up design will be £70.00.
Foam and routing will be £57.91 for 3 layers
Tool etching will be £36.45 for 27 tools.
Foam etching will be £57.00 for 3 layers.
Please note the above prices do not include shipping and VAT.
I've asked them to clarify their terminology a little bit, but it seems to be about £200 assuming i need everything doing in that list.. Which whilst that's a chunk of change, it's not completely ridiculous for what we'd end up with. Whether i'd do that in this particular tool box or buy a better one first, well that's open to discussion with myself today :)
edit.
Tool etching and foam etching are 'additional' services that can be added.
Tool etching adds up to 9 characters on each tool, like a model, part, your name, initials etc.. (not a lot of use to me in truth)
Foam etching can add a description in the foam next to each item, so if i were to use the 4mm, 5mm, 6mm allen keys like above i could have the size etched into the foam... That's possibly of more use to me, but again, i'm not sure how much.
If the foam needs etching to identify the tool then the idea of shadow foam isn't working / the user is a noob who can't recognise tools at a glance
MrLongbeard wrote: Tue Nov 05, 2024 11:22 am If the foam needs etching to identify the tool then the idea of shadow foam isn't working / the user is a noob who can't recognise tools at a glance
I mostly agree but in the instance of the below, it would arguably be a little easier with say a 2mm, 2.5mm and 3mm. But if you've stacked them correctly and know your tools anyway, you know that say the 2nd one along is the 2.5mm
MrLongbeard wrote: Tue Nov 05, 2024 11:22 am user is a noob who can't recognise tools at a glance
To add to that, sometimes they are at race meetings. I'll be working on a bike on one side of the gazebo and up to my arms in parts/grease and ask my boy or whoever is 'helping' me to pass me a particular tool at a given time lol... So their level of knowledge is unlikely to be as high as mine (or i'd be letting them fix it themselves)
weeksy wrote: Tue Nov 05, 2024 11:35 am
So they get to make multiple trips, every return journey is a learning opportunity :D
MrLongbeard wrote: Tue Nov 05, 2024 11:40 am
LOL that's when i start losing my shit as time can be a factor. Sometimes we're talking minutes for a job that arguably should take longer and you need things right fucking now :D It's OK when we're at home and doing stuff but at race meetings, time can be very much of the essence.
In truth, i don't think it's worth the extra to me in this case... but i do like it as an option.
the actual costs were honestly less than i expected, i now just need to work out a plan in terms of tools/layout.
A dymo label printer should be cheap enough on ebay
