Gear indicator
Has thanked: 1745 times
Been thanked: 2084 times
Gear indicator
Anyone installed one? What do they plug to? My RE would very much like one. 👍
Been thanked: 7526 times
Re: Gear indicator
No it wouldn't.
Re: Gear indicator
Keeps going for 7th..
Re: Gear indicator
I took one off the wife's old ER6 as it just confused her. She paid too much attention to it and it was only right 80% of the time.
I've had two bikes with factory fitted ones and only ever have a quick glance at traffic lights to make sure I'm in 1st for pulling away.
Learn speed/revs and you'll know what gear you're in without an indicator.
Has thanked: 2549 times
Been thanked: 2285 times
Re: Gear indicator
Spent years and many 000s of miles without one. Current bike has a factory fitted one.
Nice to have, but by no means essential.
Re: Gear indicator
My learning days are over... think I've just got used to them and like them mucho.
Has thanked: 2903 times
Been thanked: 2052 times
Re: Gear indicator
If you keep going for 7th maybe worth gearing it a bit longer?
Has thanked: 5449 times
Been thanked: 13085 times
Re: Gear indicator
They're pretty simple to install fella, easier on a Dyno but far from impossible on the road.
Re: Gear indicator
What do you wire to. ?
Re: Gear indicator
It needs a feed from the coils (for the revs) and the speedo.
It works out what speed/revs equal what gear... like you could do if you weren't lazy :P
You can get plug and play ones, but the one I had for the ER6 was spliced into the loom. I might still have it somewhere.
Re: Gear indicator
Plug and play for me.
Re: Gear indicator
Just watching tube and some bloke plugged straight to diagnostic block. 🤷🏻‍♂️
Re: Gear indicator
Dodgy69 wrote: Thu Oct 10, 2024 8:45 pm Just watching tube and some bloke plugged straight to diagnostic block. 🤷🏻‍♂️
Lol on a RE? Maybe on a proper bike with proper electronics yes. But an RE I'm not so sure
Re: Gear indicator
Bike is irrelevant young man, but yes, the mighty Enfield. 👍
Proper bike 😯
Re: Gear indicator
weeksy wrote: Thu Oct 10, 2024 8:45 pm
Most bikes have diagnostic sockets, I think it's been the law for a few years that they conform to OBD standards.
My 2014 Triumph Tiger 800 had a full sized (car) obd2 port and worked with my bluetooth reader. On my 2016 BMW I need an adapter to plug my car ODB2 reader in, but it still works for reading the codes, etc...
Even my 2014 Enfield 500 Bullet has Keihin EFI.
Has thanked: 2550 times
Been thanked: 6241 times
Re: Gear indicator
Can't remember which Euro*** it is, but one of them requires you to have OBD - 'cause you have to have all the cats etc so they stipulate you also need to have the on board diagnostics to check they're working.
Hence even pokey bikes will have it now.
My 1997 Speed Triple - one which the only electronics are the EFI/ECU - has an OBD port.
wull
Has thanked: 880 times
Been thanked: 1544 times
Re: Gear indicator
Post by wull »
As has been said above, I’ve fitted a few over the years and tap in to the wiring loom that goes to the clocks for your rpm feed etc. Once fitted you need to calibrate it, rear on a stand then you hold 1st at x amount of rpm then change to 2nd and hold same rpm for x amount of time and so on. It stores it for each gear and that way it will know or should know what gear you are in.
IIRC they come with instructions anyway on how to fit and calibrate. They are good but sometimes they can be a bit slow in reacting and can sometimes have a fit but more times than not when you glance down it will be correct and when you’re cruising in 6th it usually will stop you going for that ever elusive 7th as you can quickly see it within your peripheral vision.
Has thanked: 2402 times
Been thanked: 3625 times
Re: Gear indicator
I remember Mike Hailwood's reply when asked 'how many gears has it got?' - he said 'I dunno, I just keep changing up until there aren't any more'...
Has thanked: 599 times
Been thanked: 2428 times
Re: Gear indicator
The Harley is the first bike I've had that comes with one as standard, it's nice to have and comes in handy when pootling along paying more attention to the scenery than what the engine is doing.
