Proper Blown Fuse
Has thanked: 12620 times
Been thanked: 8541 times
Proper Blown Fuse
Am going out later so thought I'd check the Suzuki will start. Struggled but couldn't quite tell as had headphones on.
So turned it on again and nothing.
Then I looked at main fuse. It's melted. Even melted a little hole in plastic casing :(
It's strange how all was OK 5 seconds earlier.
Now can I just clean it all up and put a new one in?
Or best to take it to a dealer to get properly checked out?
Ta
Been thanked: 15511 times
Re: Proper Blown Fuse
Mmmm I don't like that. The obvious question is 'why'
What caused the fuse to go pear shaped.
weeksy wrote: Mon Aug 26, 2024 11:04 am Mmmm I don't like that. The obvious question is 'why'
Yup. Worried that I'll be stranded somewhere.
Have also asked on the GSXR forum to see if it's a known problem.
Has thanked: 781 times
Been thanked: 1072 times
I'd be looking for a big and broken cable, probably to the starter motor and burned.
Also. After it was dead, I hooked it up to the battery charger.
Maybe this did the big damage after the fuse blew?
Is it possible you fitted the charger the wrong way round? That's very much like a main fuse blown by fitted red to black
weeksy wrote: Mon Aug 26, 2024 11:17 am Is it possible you fitted the charger the wrong way round? That's very much like a main fuse blown by fitted red to black
No. It's got a tail bit.
Has thanked: 2558 times
Been thanked: 4169 times
That kind of damage is the universe's way of telling you to find out the root cause. Is that the main fuse? As Mussels says, I'd be checking out the big current devices like starter motor and alternator. Has the regulator/rectifier gone south?
If you fancy doing some initial troubleshooting, there are some good investigative guides here:
https://www.electrexworld.co.uk/acatalog/Technical.html
Been thanked: 14171 times
I'd want to know precisely what caused that amount of damage. Definitely not a case of sticking in a new fuse and heading off somewhere hoping for the best.
DefTrap
Has thanked: 1838 times
Been thanked: 1468 times
Post by DefTrap »
I had something similar once. There was obvious corrosion, dirt and nastiness in and around where the main fuse had plugged in - possibly water ingress over years. Looked like it overheated before it blew the fuse.
So anyway I replacd the corroded and melted parts and the fuse, never happened again in the subsequent years I owned it.
Hmm. I don't like leccy and looks like it could be a few things. I could easily half fix it and it goes again
Gonna book it into shop.
Thanks all.
Keep us posted on the outcome - be interested to know what caused it.
A_morti
Has thanked: 412 times
Been thanked: 824 times
Post by A_morti »
Like they said, that's definitely not just a new fuse and ride into the sunset.
As voltage decreases, amps increase. Or something. Anyway, if the battery was very low, it could have caused things to get hot.
Or the starter or even engine might be seized.
Or dirty/ corroded/ loose terminals on a thick wire, probably with at least one end attached to the battery, starter solenoid, engine block, or starter.
Or bring it to the man to figure it out.
Has thanked: 359 times
Been thanked: 919 times
It’s a common problem caused by cheap beer and too much sunshine.
It's booked in. They're busy, so September 24th :(
Fuck that, but a new bike until it's ready
Been thanked: 9505 times
Set it on fire, claim on the insurance.
I was obviously an electrical fault that started the fire.
weeksy wrote: Tue Aug 27, 2024 2:52 pm Fuck that, but a new bike until it's ready
I'll just ride the GasGas more. I can ride the GSXR all the next few months.
And at Portimao I'm hiring a tricked up GSXR1000 .
Didn't you have to replace the main fuse a year or so ago? Do you know why it went then?
