Tool questions
Has thanked: 10971 times
Been thanked: 4004 times
Tool questions
A thread for those odd questions that come up occasionally.
For instance:
This is a crimped fuel hose clip.
Is there a specific tool for opening these things up easily?
I have in mind a thing like a pair of pliers, but with a pair of miniature curved scythe-like jaws, or somesuch. Does such a thing exist?
Druid
Has thanked: 352 times
Been thanked: 1109 times
Re: Tool questions
Post by Druid »
They're not reuseable. I usually take a dremel to the raised bit to cut them in half
Been thanked: 2730 times
Re: Tool questions
I use long handled wire cutters or a small pair of bolt croppers.
Has thanked: 2558 times
Been thanked: 4168 times
Re: Tool questions
Those are Oetiker single ear clamps, and as Druid says, are not reusable. I find the easiest way to loosen them is to insert a screwdriver blade into the ear and twist, which removes the clamping force and allows them to be slid off the hose. In some cases you'll need two screwdrivers with different blade sizes, one to open the clamp up initially and then a larger one to open the clamp enough to slide it off.
iansoady
Has thanked: 72 times
Been thanked: 244 times
Re: Tool questions
Post by iansoady »
But to fit them? I find the best tool is a pair of carpenters' pincers.
Re: Tool questions
There are specialist pliers available. These are the spendy Oetiker ones:
https://hcl-clamping.co.uk/products/com ... number-499
Cheaper options are available, but the ones above can crimp 'head-on' and also from the side.
Has thanked: 1059 times
Been thanked: 1646 times
Re: Tool questions
iansoady wrote: Sat Aug 24, 2024 4:53 pm But to fit them? I find the best tool is a pair of carpenters' pincers.
Ha, finally, a use for carpenters pincers.
Cos they're bloody awful to use as carpenters pincers.
For my carpenters pincers I use NWS Powerbolt jobbies, but they have a huge amount of mechanical advantage (will easy cut first fix Paslode nails at 3.2mm with a urved end allows nails to be levered out withojt da.aging surfaces too much and even cut screws at a pinch) but the Powerbolt end cutters wouldn't open wide enough to do pipe clips.
Great pincers for my usage though.
