Why you need a lathe
Been thanked: 2730 times
When all you can get easily and quickly are isolation valves with compression fittings and it's to fit a flat faced bsp threaded fitting. The problem is the compression fitting tapers to an edge and not a face.
A bit of brass scratching later:
I did two, one for hot and one for cold. The cold one has been fitted and is leak free. Now I proved it works I'll do the hot, I didn't want to risk wasting water I've paid to heat .
Has thanked: 316 times
Been thanked: 1078 times
Re: Why you need a lathe
Post by Silly Car »
It does somewhat beggar belief that isolation valves are not readily available with flat mating surfaces, especially given the number of taps which are supplied with flexi hoses attached.
kendo57
Has thanked: 399 times
Been thanked: 748 times
Post by kendo57 »
I need a bigger lathe
porter_jamie
Has thanked: 253 times
Been thanked: 140 times
Post by porter_jamie »
Good work my man
There's flat faced valves available but I don't like buying plumbing fitting from random sellers. Partly quality and partly 'picture for illustrative purposes only'
kendo57 wrote: Fri Aug 16, 2024 3:18 pm I need a bigger lathe
What lathe do you have? That's a 1964 Harrison L5, ex college. I don't get anywhere near what it's capable of.
kendo57
Post by kendo57 »
I have a nice Myford Super 7, its done me ok but it does have its limits . The biggest pain is the hole through
the spindle which is only about 14mm.
kendo57
Post by kendo57 »
Colchester student is a bit of a sore point with me, i had the chance to buy a minter for £1500 with loads of accessories.
Unfortunately when it became available i was being treated for an illness and lathes were not top off my thoughts.
So i told a friend about it and he bought it , one day i hope he will get bored and sell it to me.
Picture of said lathe below
That looks lovely.
I started with my late paternal grandfather's ex WW2 repair lorry Atlas lathe. The spindle bore on my Harrison is 3/4", annoyingly small.
Has thanked: 3016 times
Been thanked: 2528 times
Screwdriver wrote: Fri Aug 16, 2024 5:02 pm You're putting an isolating valve where tap should be.
Nothin' wrong with doing that but that's why they are different. I had exactly the same issue when fitting a water filter for a neighbour. Flexi hoses are the worst of both worlds. Compression one end, tap fitting the other...
I fitted an isolating valve and a tap. I don't trust taps.
Has thanked: 780 times
Been thanked: 3224 times
kendo57 wrote: Sat Aug 17, 2024 6:11 pm Picture of said lathe below
Go and slap him upside the head with a shovel and hide the body, if that picture hadn't shown in running I'd say it'd never had been turned on.
Has thanked: 2296 times
Been thanked: 2684 times
I had three SouthBends at one point, A 9in, a Heavy 10 & a 13x60.
Another reason. I needed a drill with a 43mm collar for a single job. I've an old Wolf drill, courtesy of a skip, but the collar was 44mm.
Off we go. I ended up using friction drive, it was an awkward shape to clamp and I was only doing light cuts. Frightful bodge, lightly clamp the drill chuck stud in the tailstock chuck and off we go.
Done:
And I got to use these, left handed calipers. A boon and a blessing on a lathe.
