ZX11 stuff
- Has thanked: 1508 times
- Been thanked: 1415 times
- Has thanked: 4362 times
- Been thanked: 2852 times
Re: ZX11 stuff
You can definitely tell that the climate is kind there, reckon my garage sees more moisture than your state I imagine!
Re: ZX11 stuff
and no, I didn't omit an o-ring. For some reason there were 7 in the bag with the link.
Re: ZX11 stuff
Noticed that the ends of the exhaust is taking on a nice rainbow effect... probably something to do with the running two tanks of the good stuff through it...
- Has thanked: 9835 times
- Been thanked: 10148 times
Re: ZX11 stuff
Those stock cans get very hot after a good thrash.
Re: ZX11 stuff
Not sure about "a good trash", but it took me an hour flat from the house to the RockStore which was 81 miles on the route I took this time
and that included getting stuck behind a CHP cruiser conducting a rolling roadblock for about 4 or miles which added several minutes to the time.
Re: ZX11 stuff
ZX11 won't start... not so much as a pop as if it was trying. Gas in the carbs probably evaporated & gummed the buggers up... but can't hear the fuel pump do it's thing... It's been parked since June.
Supposed to ride it on Sunday.
Arsebiscuits.
Arsebiscuits.
Re: ZX11 stuff
Gummed up pilot jets normally, I ended up replacing mine
I googled the spec and they were £25 for 4.
I had already used a ultrasound cleaner on them
I'd tried carb cleaner , much stronger than suggested but that didn't work either
