flip a coin
Ahh, might help if I actually read the question before answering eh?Taipan wrote: Tue Nov 17, 2020 6:27 pm The problem is, the blade from the lock that you normally have to cut down is flat like this - so at 9-3 but the one in the middle of that cam thing is turned round and points from 12-6, iyswim?
I'm not 100% but pretty sure its a Yale lock? Maybe i'll just get a back but to match the new cylinder?David wrote: Tue Nov 17, 2020 6:29 pm Is there a manufacturer name on the lock? Might be best to get the appropriate cylinder or a standard yale lock.
No, its all in line as it should be. The inside bit of the lock that you turn to open the door does have a key slot in as well. I should have taken more notice and its over 30 mile round trip to go and have abetter look. I think i'll just order a new back bit (basket?) for it.chillitt wrote: Tue Nov 17, 2020 6:58 pm Is the slot for the key in line with the bar through the door? As far as I remember that bit turns freely until its connected to the the lock, so maybe thats just where its settled in the packaging
My Dad never liked plastic front doors and went for a hardwood one with frame and a yale and mortice lock combo. He's gone now and the carers never use the mortice lock, so maybe for her safety I should fit a door with multi point locking?demographic wrote: Tue Nov 17, 2020 7:30 pm Yeah, just get a Yale night latch.
Assuming thats what it is anyway.
Be aware that theres narrow ones as well as the standard ones which are set closer to the door edge.
And auto deadlocking ones.
Can't remember the sizes cos I hardly ever fit them, they don't get used much nowadays.
I get what you're saying and it makes sense for it to be as you say, but when I took the handle assembly off , that's how it was and that's how it was reassembled?maccecht wrote: Tue Nov 17, 2020 7:58 pm I assume you had the door latched open to remove the back plate so it is turned as the spring is in the latch. So remove the slotted screws rotate it to align with the new cylinder and reassemble
I'm not right keen on placky doors myself and when it came to replace my windows I didn't mind putting plastic windows in but there was no way I was putting placky doors in so I just left the frobt doorand only recently refurbed the moldings on it to neaten it up.Taipan wrote: Tue Nov 17, 2020 8:16 pm
