Tool for checking sparks....
Has thanked: 10964 times
Been thanked: 3995 times
Ok, bear with me on this, or call me crazy, i don't care.
Has anyone ever seen/heard of a tool/device for the following situation.
You own a classic bike,
You would like to check the sparks are working.
You remove the plug from the head, reattach the HT lead, then attempt to hold the threaded portion of the plug against the head, while at the same time trying to kick the bike over hard enough to get the magneto spinning fast enough.
Wouldn't it be far easier to have some sort of metal "double-ended-crocodile-clamp" that would hold the plug, and clamp to a fin so that the plug was held firmly off to one side, easily visible, well-distanced from the plug hole (thus reducing the chances of accidentally igniting any fuel/air mix), and with a guaranteed earth connection?
Does this exist?
Re: Tool for checking sparks....
Would an in-line spark checker not work for you, or do you actually want to see the spark from the end of the plug?
Big Red
Has thanked: 3 times
Been thanked: 81 times
Post by Big Red »
Anything which can clamp, can clamp the plug in place? The only requirement is that it doesn't damage something and can fit around things?
Big bulldog clip? Jump lead clamp (don't hold the other end ;) )?
Random thought - can you do it with a cunningly twisted bit of 230V solid core wire stripped and wrapped around the plug?
ChrisW wrote: Tue May 07, 2024 7:13 pm Would an in-line spark checker not work for you, or do you actually want to see the spark from the end of the plug?
I want to see the spark on the plug.
Mr. Dazzle wrote: Tue May 07, 2024 7:45 pm Anything which can clamp, can clamp the plug in place? The only requirement is that it doesn't damage something and can fit around things?
Well, yes, but that doesn't bring the plug away from the head to be easier to see.
That's nearly what I was looking for! Thanks!
Looks like that replaces the plug, but ideally I'm looking for something that holds the plug you've got.
Big Red
Post by Big Red »
Rockburner wrote: Tue May 07, 2024 7:49 pm
That's pretty much what I was looking for! Thanks!
:D
iansoady
Has thanked: 72 times
Been thanked: 244 times
Post by iansoady »
I have made something that soundes exactly what you're looking for and it's very handy. And didn't cost me a tenner.
Carpeted garage is nice, not sure I'd have gone floral myself though.
Has thanked: 7622 times
Been thanked: 5930 times
Is the HT lead long enough to reach the petrol cap? You'd get both audible and visual indication if it sparked ;)
iansoady wrote: Wed May 08, 2024 9:55 am I have made something that soundes exactly what you're looking for and it's very handy. And didn't cost me a tenner.
That is exactly what I had in mind. Got any more? :D
Has thanked: 779 times
Been thanked: 3216 times
Not got an unloved set of old jump leads you can cut the clamps off?
Gregor
Has thanked: 1756 times
Been thanked: 1153 times
Post by Gregor »
Can you use a car jumplead to acheive the same as iansoady pic ?
Sadlonelygit
Has thanked: 94 times
Been thanked: 796 times
Post by Sadlonelygit »
Couldn't find anything about the old R&R spark plug caps, but the internet provided me with........
https://speed-line.com/spark-plug-caps/ ... light-blue
I know it's not what you want, but I can't believe they still make this shit!
MrLongbeard wrote: Wed May 08, 2024 11:21 am Not got an unloved set of old jump leads you can cut the clamps off?
no - but just found the bits I need so will be making myself one of these when they turn up. :)
Sadlonelygit wrote: Wed May 08, 2024 11:51 am I know it's not what you want, but I can't believe they still make this shit!
They still make color* tunes!
https://www.gunson.co.uk/products/Colortune
*that's right, no 'u'
iansoady
Post by iansoady »
Rockburner wrote: Wed May 08, 2024 10:50 am
I just made it out of a couple of crocodile clips I had in my extensive scrap bin(s)....
As for carpet, it was there when we bought the house. The previous owner kept a couple of old Austin 7s in there. I ditched it when I realised that, kind to my knees as it was, it was impossible to find dropped screws etc....
kendo57
Has thanked: 399 times
Been thanked: 748 times
Post by kendo57 »
I have one i used to use on small plant , i think it was made by Briggs Stratton .
You can adjust the spark gap to test the strength of ignition.
maccecht
Has thanked: 25 times
Been thanked: 167 times
Post by maccecht »
Twist a bit of wire round the plug body make a hook on the end stick the HT lead on, hook it onto a convenient point
