Nice, change the oil every 8k miles not the 30k miles they can run too ! Gives them half a chance of not chewing the wet belt up. Also have a Ford dealer check the belt. Lovely vans though.MyLittleStudPony wrote: ↑Sat Apr 27, 2024 6:16 pmIt's a LWB, 2017, 2 litre diesel, automatic, titanium. Nine leather seats! The kids like it. Loads of room in the boot too.weeksy wrote: ↑Wed Mar 27, 2024 11:28 amNeeds way more pics.... SWB or LWB ? I assume LWBMyLittleStudPony wrote: ↑Wed Mar 27, 2024 11:27 am I got a Tourneo Custom LWB. Which I think is basically a Transit with nine seats.
It's pukka as fuck! I'm a vanny now! So be careful or I'll fight you outside a pub!
Buying a van
- Has thanked: 326 times
- Been thanked: 2173 times
Re: Buying a van
- Has thanked: 615 times
- Been thanked: 405 times
Re: Buying a van
I'm getting about 35mpg which isn't bad I guess as it's an auto.
How do you wash the things? I'd need a step ladder.
- Been thanked: 7526 times
Re: Buying a van
You pay an Eastern European to do it.MyLittleStudPony wrote: ↑Fri May 10, 2024 9:31 pm How do you wash the things? I'd need a step ladder.
Re: Buying a van
I see that is an option but by the time you've queued up and they've done it, I could have done it myself for nawt.KungFooBob wrote: ↑Fri May 10, 2024 9:32 pmYou pay an Eastern European to do it.MyLittleStudPony wrote: ↑Fri May 10, 2024 9:31 pm How do you wash the things? I'd need a step ladder.
"Hey Poland, you make car cleaning, make car cleaning?"
Re: Buying a van
I've been using it a bit, but not a lot. It's really only for when I've got all the kids. We're really enjoying it.
It is a little noisier than a Prius but fine.
I phoned the Ford dealer to ask them to inspect the wet belt. The receptionist sounded like she had no idea what I was talking about. But she checked the reg number for recalls. And guess what, it has one. For checking the wet belt. So Ford will do that for me, for nawt. It'll be interesting to see how that turns out.
Re: Buying a van
I called a local Ford dealer and asked if they would inspect the cambelt for me. The receptionist didn't seem to know what I was talking about and kept saying "which service do you want to bring it in for?". She asked for the reg number so she could put it in their system and check for recalls. And a recall did show up. For them to inspect the cambelt.Couchy wrote: ↑Sat Apr 27, 2024 11:45 pmNice, change the oil every 8k miles not the 30k miles they can run too ! Gives them half a chance of not chewing the wet belt up. Also have a Ford dealer check the belt. Lovely vans though.MyLittleStudPony wrote: ↑Sat Apr 27, 2024 6:16 pmIt's a LWB, 2017, 2 litre diesel, automatic, titanium. Nine leather seats! The kids like it. Loads of room in the boot too.
I took it in and they inspected the cambelt. They said it shows signs of deterioration which aren't too bad, but they're still going to replace the cambelt (and associated parts) for me under the recall.
Re: Buying a van
Result, and once done change oil a lot more regular it’ll be better for itMyLittleStudPony wrote: ↑Thu Jun 20, 2024 4:11 pmI called a local Ford dealer and asked if they would inspect the cambelt for me. The receptionist didn't seem to know what I was talking about and kept saying "which service do you want to bring it in for?". She asked for the reg number so she could put it in their system and check for recalls. And a recall did show up. For them to inspect the cambelt.Couchy wrote: ↑Sat Apr 27, 2024 11:45 pmNice, change the oil every 8k miles not the 30k miles they can run too ! Gives them half a chance of not chewing the wet belt up. Also have a Ford dealer check the belt. Lovely vans though.MyLittleStudPony wrote: ↑Sat Apr 27, 2024 6:16 pm
Re: Buying a van
I will. Two years / 20,000 miles is a crazy interval, especially for a 2 litre diesel. I think Toyota (example of a reliable brand) say all their vehicles should have their oil changed every 10,000 miles.Couchy wrote: ↑Thu Jun 20, 2024 7:33 pmResult, and once done change oil a lot more regular it’ll be better for itMyLittleStudPony wrote: ↑Thu Jun 20, 2024 4:11 pmI called a local Ford dealer and asked if they would inspect the cambelt for me. The receptionist didn't seem to know what I was talking about and kept saying "which service do you want to bring it in for?". She asked for the reg number so she could put it in their system and check for recalls. And a recall did show up. For them to inspect the cambelt.
I suspect I'll probably only do about 5000 miles a year in the van, almost all longer journeys and will change the oil at least once a year.
I should look into if the automatic gearbox needs an oil change too.
- Pirahna
- Has thanked: 1814 times
- Been thanked: 1163 times
Re: Buying a van
I've just had the oil changed in the DSG box on the T6, it cost more than the last service.MyLittleStudPony wrote: ↑Fri Jun 21, 2024 8:48 am
Re: Buying a van
I had the DSG box oil changed on my Arteon, I think it cost about £400.Pirahna wrote: ↑Fri Jun 21, 2024 11:21 amI've just had the oil changed in the DSG box on the T6, it cost more than the last service.MyLittleStudPony wrote: ↑Fri Jun 21, 2024 8:48 am
I'm not sure if the Ford has a conventional auto box or one of these modern dual clutch ones. I suspect it's the latter as it'a bit jerky.
- Has thanked: 5449 times
- Been thanked: 13085 times
Re: Buying a van
So to keep the Van thread going I've been looking/wondering into what's next for me and the lad.
I REALLY want a Transit, but the £1000 bill for the wet belt does worry me in terms of costs, along with the possibility of failure of course. I could negate this a little as it'll have Ford Warranty but i'd really prefer not to need to use that.
So it then boils down to 'what instead' The Transit was the biggest/best in terms of 3 passenger space for trips. Well, if you have a van, if you go Dual Cab then that's less of an issue, but massively shrinks the loading area for bikes.
The need and want requirements are sometimes different. If we are doing overnighters we'd LOVE to have the ability for a 'camper' / conversion. It would make certain aspects SOOOOO much nicer.
But then the weekend after we've got an uplift day where i've got 3 bikes in the back of the van, due to uplift stuff you don't want to be removing/fitting wheels each time, roll in, roll out. Which means the camper doesn't really work.
So i'm thinking something more like a MWB Sprinter really, but need to look into engines as i think they're now running the problematic Ford engine...
I'm in the Alps next week with my mate who owns a van company so going to pick his brains over beers.
- Pirahna
Re: Buying a van
My VW is what you call a dual cab. There's no bulkhead and rear seats fold or can be removed, so it's a 3 seat van or a 6 seat people carrier. There's a big size difference when you move up to the next size van, here's my ex camper next to the Kombi. The camper is on BFG's which make it look higher and the Kombi is a bit lower than standard, but you'll get the idea. As soon as you move away from a normal wheelbase van you start having to think a bit more about where you're taking it, parking it etc.
- Has thanked: 2550 times
- Been thanked: 6244 times
Re: Buying a van
Those bigger ones won't go in a lot of carparks in my limited experience.
Maybe it's just MK, but around here even all the outdoor car parks have 1.8m height barriers on entry. It's the same at the local woods etc.
Presumably intended to stop people setting up camp.
It's the sort of thing I didn't even think about or notice until it was a problem!
Re: Buying a van
I don't use car parks mate. Or at least very very rarely, enough so that it's not a consideration for what van i go for anyway.Mr. Dazzle wrote: ↑Tue Aug 06, 2024 8:39 am Those bigger ones won't go in a lot of carparks in my limited experience.
Fuel economy is a factor of course which the bigger ones will be less economical than the Custom.
I'm tempted to just go with a Custom with extended warranty at the end of the day it's looking at 60k miles for swapping the belt which is 2-3 years.
- Has thanked: 15948 times
- Been thanked: 10243 times
Re: Buying a van
For me I'd go camper. The camper is giving you a lot more benefits over the occasional inconvenience of uplift day.
Re: Buying a van
Hmmmm a reasonable point yeah... maybe.
https://www.ebay.co.uk/itm/126566691135 ... R_ikqvCkZA
https://www.ebay.co.uk/itm/126566691136 ... R_akqvCkZA
This is the sort of thing it'd be.
https://www.ebay.co.uk/itm/145899350676 ... R5TUxvCkZA
- Has thanked: 836 times
- Been thanked: 1238 times
Re: Buying a van
It seems to be regional. My transit was a fag paper under 2m and would fit in most car parks I tried* apart from Eastbourne where 1.8m seemed common.Mr. Dazzle wrote: ↑Tue Aug 06, 2024 8:39 am Those bigger ones won't go in a lot of carparks in my limited experience.
* Tunbridge Wells has several signs hanging from the roof a foot lower than the entrance barrier, most are bent.
Re: Buying a van
Nice, but check your insurance on conversions. Not sure what exactly, but it seems some people have problems with vans that don't have campervan/motorhome classification on their logbooks?weeksy wrote: ↑Tue Aug 06, 2024 10:32 amHmmmm a reasonable point yeah... maybe.
- Been thanked: 2615 times
Re: Buying a van
It's worth getting the logbook changed, you get an extra 10mph on the speed limit for dual and single carriageways compared to a van.
- Has thanked: 10263 times
- Been thanked: 6885 times
Re: Buying a van
Camper conversions can give you exactly what you want. Mine was made to get the bike in with one bed next to it.
With the bike out, it was just like any other camper.
These conversion dudes are clever.
