Swapping an XJ6 rear shock - how hard can it be?
Has thanked: 2632 times
Been thanked: 1498 times
As it was a pleasantly sunny afternoon, and mild too - and I'd walked SWMBO on top of the Chilterns y'day afternoon - I decided I'd fit the YSS rear shock I had delivered to the door a week or so back.
Although the Yamaha OE shock still has damping and isn't leaking, it's noticeably sagged and had run out of preload adjustment during my short Shropshire / mid-Wales holiday ride with t'other half. I suspect that's down to the relatively thin spring. I didn't put the two shocks side by side unfortunately since I was in a bit of a rush to finish the job by the time I finally got the old one out but in the photos, the YSS definitely looks heavier. The entire shock seems weightier too.
Anyway as the XJ is a straight push system, what could be simpler than whipping out two bolts, pulling the old shock out and popping the new one in, then replacing the bolts? The same job only took half an hour on the old GS500 and that had a proper rising rate rear end!
Ha.
Of course, everything on modern bikes is built from the middle out and everything outside the shock appears to have been put in place AFTER the shock went in on the production line.
First, it's off with the tiny side panels. On the left, it's out with the bolt, then carefully slide it off from two rubber push-on mounts - you just give it a careful tug. The right one? A bolt, a slide-off rubber mount top rear and the bottom front mount can't be accessed nor even seen. It seemed reasonable to assume it was the same as on the other side and would also pop off. Hmm. It's a bit stiff. SNAP. Damn. There's some reason some kind of push pin on the bottom front mount. So it snapped. Sigh. At least it was just the pin and not the panel. God knows how you are supposed to get that free.
OK, onward. To get to the shock's bottom bolt requires removing the footrest hanger on the offside. No big deal, three allen bolts which all came out cleanly. Then a small bracket carrying the rear hose has to be unbolted. Then the big nut can be undone and finally the bolt itself drifted clear of the eye.
But before I removed it, I tackled the top nut. This needed the rear master cylinder mounting bracket to be loosened and swung clear, then the nut could be removed - easy peasy.
At this point I drifted the bottom bolt clear - there's just about room to get in behind the chain and swing arm to get it clear. Although there was a bit of corrosion on it - assembled dry of course - it came out the other side with no fuss. So I cleaned it up, and put it to one side ready for reassembly. So far, about 30 mins.
So time to drift the top mount clear.
And this is where things got a bit stuck. There's a big bit of main wiring loom in the way. In fact there's a T junction in the loom where the wiring down to the ABS unit. This is just under the shock and just behind the gearbox. The T junction is right behind the bolt. No way to get it clear. And the loom wouldn't move. No flex at all.
Hmm.
So... off with the tank to see why the loom refused to budge. It turns out there's locating ring with a push-pin mount holding it to a bit of metal welded to the left-hand side of the frame just under the back of the tank. I managed to 'persuade' this out and that frees up a bit of play in the main loom. But that section running to the ABS is very short - I can't lift the loom to get the T in the loom clear of the back of the bolt.
So turn my attention to the ABS unit itself. I removed another bit of bracket work protecting the wiring thinking I could pop the connector out and get the movement needed. Not on your nelly. It looks like the entire ABS unit has to be removed to pull the plug out. The ABS sits up against the back of the gearbox in a steel box. I couldn't even see where it was fixed but to get in there and search for bolts seems to mean that it's not just the rear wheel out but also the plastic spray guard immediately behind the ABS unit... and that appears to be fastened to the top of the swing arm with rivets! It would appear that the only way to get the ABS off to remove the plug is to take the wheel out then remove the swing arm. Sod that for a game of soldiers.
By now it's about an hour in and time for a bit of swearing, a check in the US election, and a cup of tea.
I look at it all again. I can see half the bolt head. If I pull the cable as far out the way as I can, I'm lacking about 2mm clearance.
Time for a bit of 'easement' via some extra leverage with a tyre iron. Very gently I lean on the tyre iron. That does the trick, the head's clear, out pops the bolt which is dry of course but remarkably completely uncorroded - not bad on an eleven year old bike which gets cleaned twice a year - once in the autumn before I spray the whole thing with Mr Sheen, and once in the spring to clean it off again.
So now all I have to do is remove the shock. Of course, there's not enough clearance to remove both eyes from the brackets. Then I remember that I've propped the back wheel on a couple of blocks of wood to keep the weight off the bottom bolt as I pushed it out. I remove the prop. The extra space is just enough to work the shock round and get both eyes free. The old Yamaha shock is finally out about 90 mins after starting.
Fortunately, the reverse procedure went much more quickly, even though I was worried that as delivered, the preload was set to make the shock about 5mm longer between the eyes. But a bit of jiggling and it dropped into place. Once I'd got the top bolt back in (which a bit of easement from the tyre iron on the loom again) I just needed a third hand to lift the rear wheel to get the bottom bolt in whilst I lined up the bottom eye and pushed the bolt home. With both bolts torqued up, it was just a case of reassembling everything (and trying to remember where the small bracket had fitted - oh yes, the rear hydraulic hose), bolt the tank back down and put the side panels back, then finally the seat, remembering NOT to leave the key under the seat. That took about 15 mins.
By that time it was a bit late to go out for a ride, but a quick bounce on the seat reveals it's MUCH stiffer. I know it'll take a few miles to bed in, but I suspect the front will now be a total mismatch (but the budget's run out for this year and with training income on hold again from COVID it'll stay in the red till year when hopefully I'll get a full year's training in) but at least the rear shouldn't bottom out two-up on speed bumps any more.
I might wind a bit of preload off as the tail's sitting a bit higher than it did on the old shock but I'll see how it rides first. I'll probably take it out for a quick ride tomorrow just to see.
But boy, sometimes I think "bring back twin shocks". It took ten minutes to change the pair on my CB250RSA a few years back :)
Has thanked: 5503 times
Been thanked: 12760 times
Re: Swapping an XJ6 rear shock - how hard can it be?
Lol been there with shocks. The XSR was a pig to get out and in.
Has thanked: 9682 times
Been thanked: 9702 times
I was chatting with my local suspension guru a couple of weeks ago and he said some Ducati rear shocks are the work of the devil to remove,a time consuming task.
Seems the way with almost any modern bike,one job leads to needing to do another and before you know it,half the bike is in pieces.
Beancounter
Has thanked: 2828 times
Been thanked: 536 times
Post by Beancounter »
weeksy wrote: Sat Nov 07, 2020 6:15 pm Lol been there with shocks. The XSR was a pig to get out and in.
I assume same pig of a job as on the MT09. Getting the engine out and back in again on my TDM850 took less time. :thumbdown:
maccecht
Has thanked: 24 times
Been thanked: 156 times
Post by maccecht »
Beancounter wrote: Sat Nov 07, 2020 10:36 pm
Yeah but the engine stayed out and the conrods became fancy door handles😁
Zimbo
Has thanked: 84 times
Been thanked: 130 times
Post by Zimbo »
Out of interest, has the swap to the YSS shock made much difference? Was thinking of trying one in my ST3 as the original, 15 year old shock is a little tired and soft.
Scootabout
Has thanked: 469 times
Been thanked: 308 times
Post by Scootabout »
I've been considering upgrading the Tracer's rear shock, probably to a Hagon. I definitely won't attempt it myself, after reading that :o
Zimbo wrote: Wed Nov 11, 2020 2:47 pm Out of interest, has the swap to the YSS shock made much difference? Was thinking of trying one in my ST3 as the original, 15 year old shock is a little tired and soft.
Bit hard to give a good answer to that, as I've only done one two-up ride since fitting it, but the general feel was much less bouncy. The spring is definitely firmer, the rebound damping (which is adjustable) feels more controlled. Certainly, hitting the local speed bumps was very much more comfortable. When I get to do a solo ride over my regular training routes it'll be a bit easier to answer.
But the construction looks good and well-engineered.
Scootabout wrote: Wed Nov 11, 2020 10:45 pm I've been considering upgrading the Tracer's rear shock, probably to a Hagon. I definitely won't attempt it myself, after reading that :o
Have a look to see if there is a YouTube video. There wasn't, for the XJ... I checked ;)
Beancounter
I assume the Tracer (900?) is the same as the MT09. The biggest stumbling block I found is that there are three bolts securing the lower mount to the swingarm and they have to be put back in a certain order to facilitate getting the upper mount to fit in line with the eyelet hole. There's nothing technical, just takes patience. I've got the Tracer workshop manual and the Haynes manual which both help enormously.
I swapped my shock for a Nitron. I'm personally not a fan of Hagon. I've had two, both of them on TDM850 and neither were much better than stock. They also didn't fit correctly, the Hagon shocks being slightly longer than the OEM. When I spoke to Hagon about this (after my second purchase), they said there wasn't enough demand to make an exact TDM850 shock and I could send it back if I wasn't happy but I'd have to pay the postage. Both shocks were purchased over the phone and nothing was mentioned at the time. It's not a massive issue TBH, just shit customer service and a bike that leans over farther.
on the XSR it comes down to access to the bolt/nut. It's next to impossible to get to it.
Scootabout
It's a Tracer 700. The reason for thinking Hagon is that an acquaintance who has the same bike fitted one and says he's happy with it. He's also a lighter rider like me. I'd quite like to test his before I decide - he's offered - but I'm being v cautious about covid because my wife is a 'shielder'. I'm almost certain I'd get someone to fit it, though. I'm fairly mechanically challenged at the best of times, and don't have a garage or even a particularly good tool set.
Scootabout wrote: Thu Nov 12, 2020 8:57 pm It's a Tracer 700. The reason for thinking Hagon is that an acquaintance who has the same bike fitted one and says he's happy with it. He's also a lighter rider like me. I'd quite like to test his before I decide - he's offered - but I'm being v cautious about covid because my wife is a 'shielder'. I'm almost certain I'd get someone to fit it, though. I'm fairly mechanically challenged at the best of times, and don't have a garage or even a particularly good tool set.
I really miss my garage, and frankly, if you haven't got one and you get a bit stuck it's not so wonderful - if I got fed up with a fitting job in the garage, I just closed the door and went for a brew. I can't do that even if the bike's not actually on the road. You really DO need some decent tools - I've got some quality spanners, sockets and hex drivers, particularly in the smaller sizes where a poor-fitting tool will do real damage if the nuts and bolts are a bit stiff. Having said that, you shouldn't need a great deal of investment in the necessary tools to do one specific job.
As for access, just have a look. See what's in the way. Until I discovered the loom which was in the way wouldn't shift (plus that annoying clip on the side panel) everything was going pretty well.
It actually looks fairly straightforward - https://www.youtube.com/watch?v=l_8FV3YHk4E
Scootabout
That video was speeded up. Blatant cheating! :D
Scootabout wrote: Fri Nov 13, 2020 8:45 pm That video was speeded up. Blatant cheating! :D
To the Benny Hill music too! :shock:
Trogladyte
Has thanked: 68 times
Been thanked: 89 times
Post by Trogladyte »
I hate changing shocks. The boy's pit bike was a mare. Some of them are straightforward, but some require the swinging arm out to give clearance on the bottom bolt. Guess which variant our is? And it took pretty much all day for me and a mate who is a professional Guzzi spanner man to change the OEM for a Hagon on my 12 year old Griso.
DefTrap
Has thanked: 2269 times
Been thanked: 2086 times
Post by DefTrap »
There's nearly always something 'stupid' on vehicles.
On my ntv for example checking the front valve clearances is way harder than it needs to be. Another 5 mil or a tweak to the frame design would make all the difference.
And on the TT to change the haldex oil you need to squirt it -up- into the gearbox. Wouldn't matter so much if it wasn't 40 quid for about 1/2 a litre.
Has thanked: 5945 times
Been thanked: 4932 times
DefTrap wrote: Sat Nov 14, 2020 11:54 am There's nearly always something 'stupid' on vehicles.
In a fit of conscience, I decided one Saturday to do an oil and filter change on the 400F - but also do the sump strainer.
To get at the sump meant removing the bunch of bananas four into one exhaust system. To get at that meant removing the engine bars. Two hours later, bars and exhaust were back on, but I'd run out of time to do the sump.
Horse wrote: Sat Nov 14, 2020 12:03 pm
Sump strainer? There was a sump strainer? :D
Has thanked: 10113 times
Been thanked: 6649 times
To show some Japanese stupidity, the bleed valves on the current GSXR are on the inside.
Farking nightmare to get the tube on. Even worse getting 10mm spanner in to open and close it.
Totally stupid idea.
