Diesel heaters for a cold garage.
My garage is cold. It’s a breeze block plus brick construction, insulated and plasterboard. And it’s cold.
I don’t use it in the colder months, hotter months it is my office. I need to make that all year long - so it must be heated.
Electric heating cost a fortune to run, solar won’t heat it. To install a log burner, whilst the cosiest option by far, is £3k. So I thought a diesel heater.
Anyone here used one? Are they as crap as the reviews suggest? Garage is 5x6 meters. Want it warm.
- Been thanked: 7527 times
- Has thanked: 2404 times
- Been thanked: 3629 times
Re: Diesel heaters for a cold garage.
What thickness of insulation and on what surfaces? What is the floor construction? If it's concrete, is there insulation in the slab?
- Has thanked: 10263 times
- Been thanked: 6886 times
- Been thanked: 2617 times
The Chinese ones seem to get reasoable reviews on another forum I'm on. The actual output is less than that stated and don't muck about with the exhaust seems to be the consensus.
Could you fit a secondhand domestic central heating boiler?
There's also these things: https://ljacksonandco.com/product/devil ... el-heater/
The device exhausts inside the building, and doesn't require an external chimney? Or is that just how they're shown in the publicity pics?cheb wrote: ↑Sat Feb 17, 2024 7:22 pm There's also these things: https://ljacksonandco.com/product/devil ... el-heater/
Get one of them gas heaters that take the calor bottles, like what your nan had in her mid terrace in the 70's before she had central heating installed.
https://www.diy.com/departments/4-2kw-g ... 762_BQ.prd
- Has thanked: 6376 times
- Been thanked: 4753 times
They generate a lot of water/humidity. Unless you're going to heat the fabric of what's described as a cold garage and put in ventilation you're inviting condensation/damp. (Not to mention the CO2 levels). It's a from me.KungFooBob wrote: ↑Sat Feb 17, 2024 7:43 pm Get one of them gas heaters that take the calor bottles, like what your nan had in her mid terrace in the 70's before she had central heating installed.
- Has thanked: 484 times
- Been thanked: 1427 times
Stick with the diesel its dry heat. I have a Chinese one waiting to fit in my camperbus. A mate has one in his workshop and that probably the size of a two car garage with open roof space and its quite warm. You will need a 12v supply as well as diesel.
50mm of insulation (Kingspan) on the internal walls behind the plaster.mangocrazy wrote: ↑Sat Feb 17, 2024 6:18 pmWhat thickness of insulation and on what surfaces? What is the floor construction? If it's concrete, is there insulation in the slab?
Concrete slab is the floor. Tempted to fit a raised floor.
Detached. No option to run gas. Needs an off grid solution. I’m hoping I can power a diesel heater with a car battery and maybe a small solar charger on that.
- Has thanked: 615 times
- Been thanked: 406 times
I might be wary of log burning due to the fineable detrimental effect on air quality and health.
50mm Kingspan on the walls is good. What about the roof insulation? Heat rises and all that... A raised floor would help, especially if you can incorporate insulation. There is a particular grade of extruded polystyrene (XPS) that can withstand heavy loads and is waterproof:fingerpuk wrote: ↑Sat Feb 17, 2024 8:15 pm50mm of insulation (Kingspan) on the internal walls behind the plaster.mangocrazy wrote: ↑Sat Feb 17, 2024 6:18 pmWhat thickness of insulation and on what surfaces? What is the floor construction? If it's concrete, is there insulation in the slab?
https://www.insulationshop.co/50mm_sund ... board.html
Loft space is boarded out with 12” of insulation rolled on top. Good shout on the floor. I think sorting the floor will be a huge help.mangocrazy wrote: ↑Sat Feb 17, 2024 9:53 pm
Wood burner is a no go, due to regulation on minimal flu length and this being a listed building in conservation area the planning and dealing with the council killed that dream. Fab. My neighbours are curtain twitchers so a temp install myself will not go unnoticed.
I think that's just a publicity pic. AIUI the exhaust goes outside.mangocrazy wrote: ↑Sat Feb 17, 2024 7:30 pmThe device exhausts inside the building, and doesn't require an external chimney? Or is that just how they're shown in the publicity pics?cheb wrote: ↑Sat Feb 17, 2024 7:22 pm There's also these things: https://ljacksonandco.com/product/devil ... el-heater/
They heat a garage very well. I've an all in one unit in the garage at the moment and its drying it out nicely.
It's the second one I've used, the other is in the van, and they've proved to be very reliable. I just run it on diesel and nothing else.
