Kawasaki H1 1971
Re: Kawasaki H1 1971
All nice and tidy.
H1 - Imgur (16).jpg (2.11 MiB) Viewed 698 times
A little garage time today.
The little adjuster for the gear linkage was pretty well bodgered and the locating pins were a mix and match,so I treated it to a new adjuster and pins with a little circlip as per original.
H1 - Imgur (17).jpg (2.86 MiB) Viewed 697 times
H1 - Imgur (18).jpg (2.69 MiB) Viewed 697 times
I replaced the chain,as it was a bit ropey,the sprockets seemed fine,so I cut that corner for now.
Has thanked: 2556 times
Been thanked: 4167 times
Your H1 has done almost exactly the same miles as my 350LC. Just checked and the LC is showing 20,332.
mangocrazy wrote: Sat Dec 30, 2023 3:07 pm Your H1 has done almost exactly the same miles as my 350LC. Just checked and the LC is showing 20,332.
Pretty much the same as the Zed too,but 49 years younger!
I decided to replace the sprockets after all,for all they cost it's daft not to really.
It gives me a chance to clean all the hidden parts while the rear wheel is out too.
H1a part 2 - Imgur.jpg (1.39 MiB) Viewed 696 times
I'll get busy with the solvol on the rear brake housing. It's hard to get at on the bike.
H1a part 2 - Imgur (1).jpg (3.33 MiB) Viewed 696 times
My cush drive rubbers have a little more play than I'd like,but it's one of the parts which isn't readily available as a reproduction. Does anyone have a hack? I remember using bits of inner tube rubber to pad it out on my Z1 in the 70s,but it spat them out in no time!
H1a part 2 - Imgur (2).jpg (3.33 MiB) Viewed 696 times
Gregor
Has thanked: 1756 times
Been thanked: 1153 times
Post by Gregor »
I still use strips of inner tube on my Tenere cush drive when it gets a bit too much play and cable ties through the the sprockets and round the spokes to pull it all tight together for refitting.
Rubbing my thing in the garage kept me warm tonight.
H1a part 2 - Imgur (3).jpg (3.95 MiB) Viewed 695 times
Buckaroo
Has thanked: 1048 times
Been thanked: 1108 times
Post by Buckaroo »
Skub wrote: Mon Jan 08, 2024 9:41 pm Rubbing my thing in the garage kept me warm tonight.
Surprised you can see what you're doing after all that rubbing :obscene-birdiedoublered:
Has thanked: 5954 times
Been thanked: 3572 times
Skub wrote: Mon Jan 08, 2024 5:22 pm
Took me a second or 2 to find the swingarm, it's no bigger than the chain guard :lol: I'm too used to modern bikes
The frame and swingarm of Japanese bikes of that era were merely there to hold all the bits in approximately the correct location... :D
Yeah,Jap frames of the era were a token gesture,closer to bicycle than motorbicycle.
Gregor wrote: Mon Jan 08, 2024 5:45 pm cable ties through the the sprockets and round the spokes to pull it all tight together for refitting.
That was a very handy tip. Like all rear wheel removals and refits,there's a knack and first time is usually a cunt. With the exhausts running tight to the rear wheel there's not much room for juggling,so the cable tie trick was one less thing to balance.
Buttoned up again and ready to roll,it's bloody freezing in the garage tonight,so I'm done. Looks well though.
H1a part 2 - Imgur (4).jpg (3.8 MiB) Viewed 694 times
H1a part 2 - Imgur (5).jpg (3.52 MiB) Viewed 694 times
You missed a trick by not fitting a gold anodised 'Super Sprox' :)
KungFooBob wrote: Tue Jan 09, 2024 9:47 pm You missed a trick by not fitting a gold anodised 'Super Sprox' :)
The horror. :o :lol:
Has thanked: 20859 times
Been thanked: 13679 times
Skub wrote: Mon Jan 08, 2024 5:22 pm I decided to replace the sprockets after
Cut up a plastic milk bottle?
Taipan wrote: Wed Jan 10, 2024 5:30 am Cut up a plastic milk bottle?
In the end I padded it out with strips of rubber,we'll see how long that lasts.
Been thanked: 1228 times
Maybe tight metal shims.
Tricky
Has thanked: 3043 times
Been thanked: 3309 times
Post by Tricky »
:thumbup:
Really is a lovely looking thing, and a credit to you and whoever did the resto.
Love the look of the case paint
Tricky wrote: Wed Jan 10, 2024 10:56 am :thumbup:
It's definitely heading towards concours condition... :thumbup:
