Lock and chain recommendations - is Almax still the one to have?
Has thanked: 10265 times
Been thanked: 6886 times
Re: Lock and chain recommendations - is Almax still the one to have?
Yorick wrote: Fri Nov 24, 2023 7:14 pm
Supermofo wrote: Fri Nov 24, 2023 2:02 pm Those litelock D locks are supposed to be good against angle grinders. Eventually go through but take more than 1 disc in tests I've seen.
Aren't the cylinder locks easy to pick? Or is that summat else?
Tap tap. Can you hear me?
Has thanked: 599 times
Been thanked: 2443 times
Yorick wrote: Fri Nov 24, 2023 9:09 pm
All locks are easy to pick, have you never watched the LPL or Bosnian Bill
MrLongbeard wrote: Fri Nov 24, 2023 9:23 pm
Yes. Love them. But didn't that big fat lad from VD reckon he could open the locks with a biro?
Has thanked: 4361 times
Been thanked: 2851 times
Yorick wrote: Fri Nov 24, 2023 9:24 pm
Sorry, had to do the scouts run.
I don't believe that's the case anymore, although I could be wrong.
The LPL can pick anything but concensus seems to be that scrotes pretty much never pick locks
Has thanked: 6191 times
Been thanked: 5087 times
Apologies for the confusion. It was the Hiplok that I'd suggested and showed an image [much] earlier in the thread.
Scootabout
Has thanked: 479 times
Been thanked: 310 times
Post by Scootabout »
"Call that a chain? THIS is a chain" :)
https://securityforbikes.com/proddetail ... od=P25-x.x
Scootabout wrote: Mon Nov 27, 2023 11:10 pm "Call that a chain? THIS is a chain" :)
It is almost twice the weight of our 19mm chain
:o
Supermofo wrote: Fri Nov 24, 2023 9:49 pm
Yorick wrote: Fri Nov 24, 2023 9:24 pm open the locks with a biro?
That was the 'tubular' type keys. IIRC it cost one lock manufacturer a small fortune in supplying replacements.
A few years back, in the office, the key to unlock a laptop from a caddy was lost. One of the lads chewed a pen lid to soften it, lock open.
Has thanked: 1947 times
Been thanked: 1292 times
Post by Jody »
Yorick wrote: Tue Nov 21, 2023 6:19 pm Dig a hole.
Drop a pole into concrete.
Weld the genny to the pole.
An Angle grinder that will go through a pukka chain will make light work of a few welds !
