What have you done to your bicycle today ?
Beancounter
Has thanked: 3126 times
Been thanked: 684 times
Post by Beancounter »
Mr Moofo wrote: Tue Sep 05, 2023 8:27 pm
weeksy wrote: Tue Sep 05, 2023 6:56 pm Mmmm indeed. I'll be curious to know the answer here.
I would like to find a wheel building course
I've got a wheel building book by Roger Musson which is very helpful - happy to email it over.
Has thanked: 1926 times
Been thanked: 1728 times
Beancounter wrote: Sat Sep 16, 2023 9:18 pm
Yes please!
I will send you a PM
Taff
Has thanked: 334 times
Been thanked: 1191 times
Post by Taff »
I rode my Ghost around Glastonbury & Wells yesterday and it didn't really feel great, so I've just pulled every bearing in the linkages to find nearly every one of them is seized :oops: :oops:
I swapped out the bottom bracket bearings while it's apart as well
Has thanked: 3644 times
Been thanked: 2502 times
Opened up the Trek Madones BB. Rusty water following the crank spindle out told the story. NDS bearing is shot, still spins but very very rough, so I've flushed it out, repacked it and its off to the LBS for new bearings once the Evil comes back with serviced boingy bits.
mboy
Has thanked: 854 times
Been thanked: 696 times
Post by mboy »
Where do you live?
Currently teaching a friend of mine... We built these wheels the other day for my full sus...
Got another pair to do with him later this week... This time I'll just be supervising.
Serviced the Curtis' BB, rear wheel bearings, jockey wheels, put a bit more self amalgamation tape on the chain stay where it was wearing thin, serviced the One Up dropper which is really easy, its been properly designed to be service at home with no special tools. It's ready for another month or so's sodden Sarf Dahns riding now.
Yesterday I did my partial commute to work from Scarfolk-on-Sea to Lewes along the new cycle path, about halfway along the 13 mile trip it turned into monsoon like conditions so this morning I dropped out the crank and dried out the seals and BB before popping the new bearing seals (that were fitted yesterday) and packing them with the special grease. Reset gears and tweaked the saddle height.
Been thanked: 15493 times
MingtheMerciless wrote: Wed Nov 01, 2023 10:16 am Yesterday I did my partial commute to work from Scarfolk-on-Sea to Lewes along the new cycle path, about halfway along the 13 mile trip it turned into monsoon like conditions so this morning I dropped out the crank and dried out the seals and BB before popping the new bearing seals (that were fitted yesterday) and packing them with the special grease. Reset gears and tweaked the saddle height.
Funnily i re-did 2 of his pivot bearings with the magic grease yesterday and 2 new bearings :)
Riding home from the station this morning and one of my shoes wouldn’t clip in properly, thought I knew what it was so carefully pedalled home and on arrival my suspicions were confirmed, the spring pin had worked loose , nearly too loose as any further and the pedal explodes.
A bit of fiddling, pushing home and bodging with Sikaflex and hopefully good for a few more miles.
It's not secured at the end? Or is it threaded on the other end?
what new cycle path?
Mr Moofo wrote: Tue Feb 13, 2024 8:02 pm
Polegate to Firle, it runs alongside the A27 but mostly your far enough away that it’s not too intrusive or feeling like your riding on a pavement next to a busy road
weeksy wrote: Tue Feb 13, 2024 6:34 pm It's not secured at the end? Or is it threaded on the other end?
Nope, it relies upon the knurling holding it too the plastic pedal body, it works OK but as they age it becomes a weak point and the pin can work loose, shame as they are brilliant pedals for me.
Fitted a new dropper post guard after I put the other one ina “safe” place last year and had to strip a rebuild the dropper the other day after a couple of months of muddy rides without it being fitted .
A what now?
One of these, helps keep the mud off the post.
A
MingtheMerciless wrote: Wed Feb 14, 2024 9:30 pm One of these, helps keep the mud off the post.
Does it actually work?
Yep stops the dropper stanchion becoming completely encrusted in tyre fling. It does get a bit dirty but nowhere near as bad as if you don’t run one.
Mine is clean after every ride as half the time it's down, so it self wipes... I can see why keeping it clean even when up would be useful though.
Broken it, my pedal "fix" lasted two rides before the pin and spring ejected itself 12 miles from home (I suspect at the top of Firle Beacon). FFS. Now no one has either XC6 or XC8's in stock at a sensible price.
