Oil change regardless..🤷🏻‍♂️
Has thanked: 2863 times
Been thanked: 3518 times
Do you change your bikes engine oil every year regardless of mileage, every 2 years regardless of mileage or mileage as per book. Thinking more about multiple bike ownership.
porter_jamie
Has thanked: 253 times
Been thanked: 140 times
Re: Oil change regardless..🤷🏻‍♂️
Post by porter_jamie »
100% yes. Yearly even if it's only done mot centre miles. It's not the drive to work shitter car I don't care about, however that also gets done yearly regardless of miles too. No downside to it at all apart from cost and potential of stripping the sump plug threads.
DefTrap
Has thanked: 1838 times
Been thanked: 1468 times
Post by DefTrap »
I change the oil every time I remember
I have heard in the past about oil deteriorating due to condensation or whatever, even if its doing nothing, so maybe it's best to spend £50 for peace of mind. 👍
Has thanked: 10971 times
Been thanked: 4004 times
Approximately to mileage for me, which is probably about once a year now.
Been thanked: 2730 times
Mine get fresh oil on every second stroke of the engine.
Been thanked: 4529 times
Mileage, it isn't going to do anything to the oil sat in the garage
Been thanked: 14171 times
Mileage for mine,they don't usually sit for long.
Car gets once a year,because I don't care much about it.
porter_jamie
Le_Fromage_Grande wrote: Sun Oct 01, 2023 5:04 pm Mileage, it isn't going to do anything to the oil sat in the garage
Oil is hygroscopic, so actually yes it can age. For something you care about, once a year
Been thanked: 9505 times
porter_jamie wrote: Sun Oct 01, 2023 7:34 pm
I'm 50/50 on this.
I get that oil sat in an engine could absorb moisture in the air and oil does 'age' without being used.
But then, surely when oil gets up to 100c the water content just boils off out of the crank case vent?
porter_jamie
You want steam Inside your engine?
porter_jamie
Clogging up your breathers with emulsion?
porter_jamie wrote: Sun Oct 01, 2023 7:53 pm You want steam Inside your engine?
How much water has the oil absorbed, how much steam does it create, how long does it take to vent out the crank case, how much damage does it cause?
I don't know, that's why I'm 50/50.
porter_jamie
Why would you take the risk
porter_jamie wrote: Sun Oct 01, 2023 8:01 pm Why would you take the risk
The cost of the oil
The environmental cost of disposing of the oil if it doesn't need to be replaced
This dammed idleness
Not sure this engine starting at the weekend over winter helps much with this. I was once told to leave alone unless your going out for 20 miles +.
porter_jamie wrote: Sun Oct 01, 2023 7:54 pm Clogging up your breathers with emulsion?
There's always steam inside your engine, and I'd love to see it clog the breather on my Kawasaki
Has thanked: 1187 times
Been thanked: 2281 times
KungFooBob wrote: Sun Oct 01, 2023 7:38 pm
I'm 50/50 on this.
Yeah, it might be technically hygroscopic but not to the same degree that brake fluid is for example. Completely agree that the tiny amount of condensation that forms would be driven off with heat but that wouldn't result in an engine 'full of steam'.
I change the oil in the track bike at least once a year but if I'm not doing the miles on the other bikes (or cars) I'd be happy to do it every other year or indeed maybe even longer. It's not going cause any wear.
Has thanked: 780 times
Been thanked: 3224 times
Mileage based for my fleet of 2 bikes and 2 cars, always have always will.
I suspect that time based, rather than distance based servicing was invented by the dealers to boost workshop income.
I'm sure up until recently (well early 2000's is recent for me) that it was always mileage and never time...
..but then, has oil technology and engine performance moved on since then?
