Yes there is wood on my bike.Mr. Dazzle wrote: ↑Sun Sep 24, 2023 8:00 pm
Ally vs. Steel is gonna be basically the same when you're comparing steel vs. CF for example. Wood is way more damped than CF though, which is why CF piano boards are really good, but CF bells are shite, IYSWIM.
Which material damps vibration best - steel or aluminium?
- Has thanked: 262 times
- Been thanked: 1278 times
Re: Which material damps vibration best - steel or aluminium?
- Has thanked: 255 times
- Been thanked: 143 times
- Has thanked: 2418 times
- Been thanked: 3662 times
At the moment that's precisely what I've got. The RH bar with the eBay rubber bushed bar end weight vibrates a small but noticeable amount, the LH bar with no bar end weight (it vibrated out) vibrates significantly more...
But it's instructive that in over 11,000 miles of ownership I've never felt the need to complain about vibes through the bars and in all that time I've had the standard Aprilia mass damper insert and bar end weights fitted.
The problem has only reared its head when those have been removed.
Yeah, steel is way more forgiving. After thinking about it and reading the stuff on here, I'll be re-fitting the OE Aprilia bar end tackle to my steel Ace bar copies:Mr. Dazzle wrote: ↑Sun Sep 24, 2023 8:53 pm Honestly I'd use steel for a way more fundamental reason.
You can get away with a lot using steel Tough as old boots, doesn't mind being dinked a bit, much easier to weld....
I suspect Aprilia used ally for cost more than anything. Or cost/weight/stiffness optimisation.
viewtopic.php?p=253377#p253377
In the meantime (and seeing as I'm in France and all the OE Aprilia bits are in Sheffield) I'll just have to live with slightly tingly digits.
- Has thanked: 542 times
- Been thanked: 7598 times
- Has thanked: 609 times
- Been thanked: 4133 times
Put them back in thenmangocrazy wrote: ↑Sun Sep 24, 2023 9:13 pmAt the moment that's precisely what I've got. The RH bar with the eBay rubber bushed bar end weight vibrates a small but noticeable amount, the LH bar with no bar end weight (it vibrated out) vibrates significantly more...
That's what happens when you only read the last couple of posts in a thread.Le_Fromage_Grande wrote: ↑Sun Sep 24, 2023 10:20 pmPut them back in thenmangocrazy wrote: ↑Sun Sep 24, 2023 9:13 pmAt the moment that's precisely what I've got. The RH bar with the eBay rubber bushed bar end weight vibrates a small but noticeable amount, the LH bar with no bar end weight (it vibrated out) vibrates significantly more...
- Has thanked: 6245 times
- Been thanked: 5120 times
Wasn't there a product call 'Bar Snake', a flexible weighted ... thing ... that was pushed along the length of the 'bars?
Edit: there still is: https://www.barsnake.com/index.php/about-barsnake
They say it 'dampens' rather than 'damps'.
Oh the horror...
There are so many fails in just the first sentence on their home page that it really isn't funny:
The Barsnake eliminates harmonic resonate frequencies that eminate from cylic engine vibrations that are transmitted through the vehicle frame to the handlebars. The Barsnake dampens out these resonate vibrations because the polymer of the Barsnake has a low hysterisis factor, which means that the polymer doesn't transmit vibrations.
Oh the horror...
They're Americans. English is a foreign language
- Has thanked: 1765 times
- Been thanked: 2107 times
What happened when they put a strip of rubber at your clamps.
I didn't know they had...
Not entirely sure what you mean, old bean. The OE Falco bars have a nifty little arrangemnt that's not easy to explain in words, so here's a parts diagram.
My problem is that I needed different bars to work with the risers and I never adapted those bars to accept the OE Falco anti-vibration system. And the bike (and me) are in France and all the bits are in Sheffield.
- Has thanked: 2572 times
- Been thanked: 6303 times
If the OE system uses a kind of tuned mass system...well, stating the obvious but it's unlikely to be tuned to the new setup!
Can't work out if that's what's going on here. Is that what number 4 is?
- Has thanked: 6416 times
- Been thanked: 4798 times
1,4,5,6,9,10,11.Mr. Dazzle wrote: ↑Mon Sep 25, 2023 5:47 pm If the OE system uses a kind of tuned mass system...well, stating the obvious but it's unlikely to be tuned to the new setup!
Like I say, wind it in, wind it out. I know some have gone a bit about resonant frequencies but the bar vibration that bothers the rider is all about when the engine vibes resonate through the bars. If they vibrate uncomfortably throughout the rev range, I'm wrong.
Ah yeah...if its adjustable, retune it
The parts diagram gives an idea, but it's not entirely obvious. The long rod (4) has a rubber sleeve (5, I think) at the end that goes furthest into the bars and the rod protrudes through the part (6) that screws into the bar end. The long rod also has a hole drilled in it, through which a pin (9) is inserted, with an o-ring (10) behind it. The actual bar end weight (1) has a groove machined in it to locate the pin (9). A small allen bolt (11) fixes the bar end weight to the end of the long rod (4).
I'm sure that explanation makes it all much clearer...
- Screwdriver
- Has thanked: 267 times
- Been thanked: 769 times
Yes there would be a noticeable difference. No you won't know what difference it will make until you try it.mangocrazy wrote: ↑Sun Sep 24, 2023 7:12 pm Following on from my 'ramblings' post, I was wondering what difference a choice of material (i.e. steel instead of aluminium) would make to the vibration absorption (or rejection) properties of handlebars made of differing materials. Would there be any noticeable difference between a set of steel bars compared to a set of ali bars?
Chances are, the manufacturer will have dialled out vibration for whatever OEM fitting they decided to use so there is a higher probability that changing anything will make it worse. That might even be true for bar end weights. If the mfr could make the handlebars vibrate less, they would have tuned the end weights already.
If you change the bars (or the entire handlebar mounting!) you're starting from scratch so you might as well suck it and see. Steel or aluminium makes "no difference". You can't say one is "better" than the other until you try them. It may be that the particular mounting happens to work best for steel, it might work best for ally but there are too many fantastically complex parameters to even think about calculating a response.
I would hazard a guess that changing the length and shape of the bars would have just as much effect as swapping steel for aluminium.
Plato
Plato
Looks to be almost like a 'pendulum' mounted to swing from the bar end weight. Perhaps giving some sort of 'longer bar' effect. Or it works almost like a balancer shaft in an engine?Mr. Dazzle wrote: ↑Mon Sep 25, 2023 5:47 pm
- Has thanked: 1361 times
- Been thanked: 1749 times
An aid to lessening vibration on KX500s was something called a Bar Snake which although I've never tried or even seen one up close didn't seem a kick in the arse off a bit of flexible pipe filled with builders silicone.
Not tried it but its cheap enough to have a go.
