Just Because You Can.....
- Has thanked: 781 times
- Been thanked: 1072 times
- Has thanked: 222 times
- Been thanked: 788 times
Re: Just Because You Can.....
No, thats the car equivqlent of someone with too much time and money with absolutely no sense of taste, or sense....
- Has thanked: 20859 times
- Been thanked: 13679 times
Wreckless Rat
- Has thanked: 666 times
- Been thanked: 704 times
- Been thanked: 9495 times
That's something they do in one of the Nordics.
There's a specific class of license that 16 years olds can hold, but it has to only have two seats and have a limited speed, so normal cars get converted in to these bastardised pickup things. They call them EPA Traktors.
- Has thanked: 7622 times
- Been thanked: 5930 times
Wreckless Rat wrote: Fri Oct 09, 2020 10:00 am I've owned worse...
I once owned a mini metro pick up conversion...![]()
Wreckless Rat
I don't have one of mine, but it pretty much looked like this - same colour too.... But mine had a ply and stained hardwood buck lining....Horse wrote: Fri Oct 09, 2020 10:29 amWreckless Rat wrote: Fri Oct 09, 2020 10:00 am I've owned worse...
Photo?
As the article says, looks better than it should.Wreckless Rat wrote: Fri Oct 09, 2020 10:43 amI don't have one of mine, but it pretty much looked like this - same colour too.... But mine had a ply and stained hardwood buck lining....Horse wrote: Fri Oct 09, 2020 10:29 amWreckless Rat wrote: Fri Oct 09, 2020 10:00 am I've owned worse...
Photo?
- Has thanked: 602 times
- Been thanked: 4528 times
The Escort is massively wrong, but somehow right.
Has he made the windows look smaller by painting the glass?
As for Wratty's metro pick up - what do you expect from Norfolk?
Dunt look bad to me,then again wagons don't exactly flick my switch.
I'd bet Nik Samson would like that!
Wreckless Rat
It was a POS - but it was cheap, and I had this idea (hahaha) it would be sort of functional... You could fit one bale of straw in it, just. Need at least a couple of bales of straw when fingering your sister....
Julian_Boolean wrote: Fri Oct 09, 2020 1:22 pm As for Wratty's metro pick up - what do you expect from Norfolk?
- Has thanked: 1059 times
- Been thanked: 1646 times
- G.P
- Has thanked: 1994 times
- Been thanked: 1283 times
A mate of mine had a Mini Pickup back in the early 80's, he bought it already "done". It had a nicely sorted 1275 motor in it,
It had a wooden floor in the "bed" and a quality cover, a subtle paint job and 10" revolution wheels. Noice!
2 things I vivdly remember about were that the sound deadening in it was aces as the cab was so small. Also, because it was a pick up, it was even lighter at the back than a normal mini so the back end would get very lively, unusual for a FWD car, but familiar to anyone who drove a mini enthusiastically
I've always fancied one.
Solid looking ones are being advertised for over £15k on the bay...
Guy I knew had a Berkley, built IIRC with a 350cc two stroke engine.G.P wrote: Fri Oct 09, 2020 6:52 pmt was even lighter at the back than a normal mini so the back end would get very lively,
Some wag had replaced that with an 850 mini subframe. Under firm acceleration it would sit still with its wheels spinning.
- Has thanked: 1080 times
- Been thanked: 1010 times
I think it was from a van...different roof line.Julian_Boolean wrote: Fri Oct 09, 2020 1:22 pm The Escort is massively wrong, but somehow right.
- Has thanked: 779 times
- Been thanked: 3216 times
