Leaking fork seal
- Trinity765
- Has thanked: 2442 times
- Been thanked: 2398 times
Leaking fork seal
I have never had a leaking fork seal before so I'm after any advice that you have to keep me calm.
I noticed at the weekend the tell tell sign of a black oil line around one of the front suspension forks. I wiped it off and forgot about it. I went out yesterday, did less than 30 miles and noticed when I got home that it had leaked again - sorry no pics. I left a message on the Triumph dealership's answerphone. The bike has over a year of warranty and I've not hit any large potholes so I've not looked for any damage to the wheel and I'd be very surprised if there was some - just the leaky seal.
I'm off to the Picos and Pyrenees in 11 days so trying not to panic.
- Has thanked: 5453 times
- Been thanked: 13102 times
Re: Leaking fork seal
It's no panic, your dealer should sort easily and quickly. Whether it's classed as warranty or wear and tear is open to debate but it's a 30 minute job.
- Trinity765
Thanks. I've Googled it, of course. There's a tool that you can buy - a bit of plastic, that you can run around the seal - if the dealer can't fit it in I shall cut up a plastic milk bottle and 'ave a go myself
How much oil can you afford to lose before needing a top up?
Yeah there's tools, i've not used but many on here will have, give them a chance to get out of bed They'll offer a bit of wisdom shortly.Trinity765 wrote: ↑Wed Jun 14, 2023 6:11 amThanks. I've Googled it, of course. There's a tool that you can buy - a bit of plastic, that you can run around the seal - if the dealer can't fit it in I shall cut up a plastic milk bottle and 'ave a go myself
I rode back around and back from germany with a leaky one... it was fine "we'll sort it when you get back" was the dealers reply... it didn't cause any issues.
- Has thanked: 310 times
- Been thanked: 568 times
The lost oil is a problem, but the bigger problem is getting fork oil on your brakes. The tolerance there is pretty much zero.
Sounds like you have it in hand though.
- Has thanked: 6382 times
- Been thanked: 4763 times
Is the line actually black? When you wipe it, how oily is it? (It does sound like the seal needs reseating to me 'cos being black etc but I'm definitely no expert!).
- Trinity765
When I noticed it at the weekend it was black - which I cleaned off. Yesterday it was clean oil colour (beige/clear).Count Steer wrote: ↑Wed Jun 14, 2023 6:54 am Is the line actually black? When you wipe it, how oily is it? (It does sound like the seal needs reseating to me 'cos being black etc but I'm definitely no expert!).
- Has thanked: 7821 times
- Been thanked: 2531 times
In the short term tie a rag around the top of the fork led to stop the dribble going down the fork leg.
I had the same problem, even though I had both fork seals replaced last year.
This seems to have solved it.
Risk Racing 00-123 Small 35mm - 45mm Seal Doctor, Small (35 millimeters - 45 millimeters) , Red https://amzn.eu/d/7jIlwLB
- Been thanked: 4124 times
Are they right way up or upside down forks, right way ups are less hassle with a leaky seal
- Has thanked: 3261 times
- Been thanked: 1737 times
I wouldn't panic over a leaky fork seal,It's not ideal but it's not a show stopper.The damping will change,depending on how much oil has leaked outTrinity765 wrote: ↑Wed Jun 14, 2023 5:11 am
The most important thing is trying to keep the oil off the disc & contaminating the pads.
As the bike's under warranty take it back to Triumph .
- Has thanked: 10276 times
- Been thanked: 6891 times
On my GSXR1000, so much oil dumped onto the tyre and I crashed down Craner Curves. Suzuki refused to replace the fork seals. I even took the forks to Suzuki HQ in Milton Keynes.Bustaspoke wrote: ↑Wed Jun 14, 2023 9:18 amI wouldn't panic over a leaky fork seal,It's not ideal but it's not a show stopper.The damping will change,depending on how much oil has leaked outTrinity765 wrote: ↑Wed Jun 14, 2023 5:11 am
- Tricky
- Has thanked: 2568 times
- Been thanked: 2680 times
I've got something very similar to that and it has worked well on various bikes.ninja wrote: ↑Wed Jun 14, 2023 8:40 am I had the same problem, even though I had both fork seals replaced last year.
As others have said, chances are it's just a bit of detritus in there and something like the above ( or SealMate, or end of a zip-tie or maybe even milk bottle) will solve it.
Only ever had to use it a couple of times on the road bikes, but had the same issue on my ZX6 last year and have had it a fair few times on the off-roader- you lose a little bit of oil but nothing significant if you know what you're doing and don't have weight on the forks.
Having said all that, as it's still under warranty, I wouldn't be doing any of the above just yet- I'd ride it to my local Triumph dealer, explain that you're off on a big trip shortly F2F and see if you can get one of their techs to have a look / sort it
- Trinity765
I'm a little bit annoyed with Triumph already (that didn't take long).
When I say I popped out on the bike yesterday, it was actually to go to the dealers and pick up a couple of belly pan bolts which I'd ordered and it was when I got home I noticed the leak was back. It was 4.30pm and I phoned them twice without getting through so left a message. I've just phoned them as they haven't returned the call and said "Hi, I left a message late yesterday" and the guy said "Yeah - about the bolts". I said "No, about the suspension". They had listened to the beginning of the messaged, assumed it was about the bolts and skipped to next message.
They're seeing now if they can put it through as a warranty claim but panicking as they know I'm away on the 25th and they already can't fit me in.
I'm going to end up sorting this out for myself.
- Trinity765
Upside downLe_Fromage_Grande wrote: ↑Wed Jun 14, 2023 9:13 am Are they right way up or upside down forks, right way ups are less hassle with a leaky seal
- Has thanked: 1055 times
- Been thanked: 861 times
Seal mate works well, used mine a few times.
When the Supermoto group from VD went to Corsica, I learnt that a strip of 35mm wet film was most effective at cleaning grit and dust out of KTM fork seals.
I'd be most surprised if Triumph sort them under warranty, but good luck.
- Has thanked: 620 times
- Been thanked: 407 times
I think for my first two years of riding my bike always had a leaking fork seal. I was too skint to get them fixed. I used to wipe the oil away before MOT tests.
I'd be very impressed if anyone can change them in 30 minutes, I'd have thought more like two hours. 20 years ago I think 100 quid was a good deal for getting them done, all in.
IIRC it was a 30 min job on the LCs.MyLittleStudPony wrote: ↑Wed Jun 14, 2023 2:12 pm I think for my first two years of riding my bike always had a leaking fork seal. I was too skint to get them fixed. I used to wipe the oil away before MOT tests.
But I watched the lad split the forks on my Husky TE300i. Needed 2 special tools.
- Has thanked: 2407 times
- Been thanked: 3637 times
It's a lot more involved replacing fork seals on USD forks compared to RWU, and normally involves at least one special tool. Certainly try a seal-mate (or similar) to remove any detritus that may be present, but wrap some cloth arouind the lower fork leg first as the action of introducing the seal mate may cause the loss of a bit of fluid. I'd also be very carefully checking the errant fork stanchion for any nicks, scratches or pips which may have disturbed the fork seal. Ideally you'd put the bike on the centre stand (if it has one) and get the front wheel off the ground so the forks are at full extension before checking. Check all round and as much of the visible fork stanchion as you can.
It's a 30 minute job on rwu forks so long as the old seal comes out easily.Yorick wrote: ↑Wed Jun 14, 2023 2:59 pmIIRC it was a 30 min job on the LCs.MyLittleStudPony wrote: ↑Wed Jun 14, 2023 2:12 pm I think for my first two years of riding my bike always had a leaking fork seal. I was too skint to get them fixed. I used to wipe the oil away before MOT tests.
On USD forks it's an arse of a job
