Diverting water from an outdoor sink or use on the garden
- Mr Moofo
- Has thanked: 1849 times
- Been thanked: 1482 times
I have an outdoor sink - and old stainless pot wash sink. I now get used far more than I ever expected.
The wast water just flows into the drain. I would like to somehow be able to divert the grey water to use on the garden. Can anyone give me a sensible solution where most of the water can so via a hose (the plot slopes away from the sink).
Any ideas?
Any ideas?
- Has thanked: 6413 times
- Been thanked: 4797 times
Re: Diverting water from an outdoor sink or use on the garden
Can you stick a collection container with a Hozelock compatible tap under it? eg an old homebred keg.
What sort of volume of water are you putting through it?
- Has thanked: 840 times
- Been thanked: 1242 times
A rain diverter for miniflow might be workable on the sink waste pipe.
https://www.ebay.co.uk/itm/313400514568 ... 99a94f2c96
I looked at something similar a while back and read that reusing grey water on the garden was a bad idea, I guess it depends how grey that water is.
- Has thanked: 6239 times
- Been thanked: 5120 times
If there's a hosepipe ban, this will still fall foul (grey) of it. Beware nosey neighbours.
Hosepipe ban rules are worth a read for specifics, last year I found out it was ok for me to carry on using a hosepipe inside the house from the mains tap and I could use a hosepipe outside as long as it wasn't connected directly to the supply.
This was so I could recycle aquarium water into butts and then refill it.
Never thought about it other than 'hosepipe ban' = 'hosepipe must not be connected to mains supply'. It would be pretty stupid to ban 'em if they're connected to eg rainwater butts. Less confusing for nosy neighbours if they're just not allowed I suppose.
I could use my submersible pump to pump bath water out onto the garden or in to storage and obvs people would take the p if that was OK. Fill the bath, hop in, hop out, hey presto grey water. So I can see why they might include piping grey water around in the ban.
- Mr Moofo
Hmm - not sure if enough room. Will report backCount Steer wrote: ↑Thu Jun 08, 2023 9:12 pm Can you stick a collection container with a Hozelock compatible tap under it? eg an old homebred keg.
- Mr Moofo
It's just from washing boots, bike helmets, the dog, outdoor stuff - so not heavily polluted. But it would be better on the tomatoes than down the drain.Mussels wrote: ↑Thu Jun 08, 2023 10:01 pm A rain diverter for miniflow might be workable on the sink waste pipe.
What I can find is a diverter than can be switched
- DefTrap
- Has thanked: 2276 times
- Been thanked: 2199 times
I had my kitchen sink like this for months when I slowly renovated the kitchen ...Count Steer wrote: ↑Thu Jun 08, 2023 9:12 pm Can you stick a collection container with a Hozelock compatible tap under it? eg an old homebred keg.
The only diverters I have are house drain sized for diverting into a water butt. They aren't switchable).Mr Moofo wrote: ↑Fri Jun 09, 2023 5:41 pmIt's just from washing boots, bike helmets, the dog, outdoor stuff - so not heavily polluted. But it would be better on the tomatoes than down the drain.Mussels wrote: ↑Thu Jun 08, 2023 10:01 pm A rain diverter for miniflow might be workable on the sink waste pipe.
The reason I thought of homebrew kegs was because I recently bought a replacement tap for a water butt - with a more Hozelock compatible nozzle - and it was advertised as suitable for homebrew beer kegs. If you could cut a homebrew barrel down to size to fit under, the crud would settle below the outlet (you always had to tilt them to get the last of the brew out ) and you could connect a hose running down the slope to a bigger container perhaps.
You can also get a fitting for the drain with a tee-off (they do them for feeding in condensate from boilers so it could be tweaked to divert water out maybe).
- Mr Moofo
Following on from this suggestion - I may just add a long piece of waste pipe and a connector to get it as far as the lawn
