Dremel type tools
- Been thanked: 14171 times
Dremel type tools
I've a Dremel 300 which has lay down after not a great deal of use. The culprit appears to be the mains switch,which is about 30 quid. Since this is a fair slice of the price of a new one and more expensive than some of the copies,I'm wondering whether to take a punt on an ebay cheapie.
Has anyone had experience of the cheap shit,is it cheap shit,or is Dremel just overpriced,cheaply made shit.
- Cousin Jack
- Has thanked: 3016 times
- Been thanked: 2528 times
Re: Dremel type tools
I have a Lidl version. It works, not exactly high quality but it was less tha £30. For occasional use it is fine.
- Been thanked: 2730 times
I've a Lidl one too, I was given it for helping someone move some machinery in their shed. It does what I need.
Your analysis of Dremel seems fair from what I've read.
- Has thanked: 781 times
- Been thanked: 1072 times
I had a Lidl battery one, it was gutless. I noticed they binned that version and went back to mains power.
The spindle lock also broke very easily, not abused the new one yet to see if it's still the same.
- Been thanked: 9505 times
I've got a battery Dremel, it works well and it's had some proper abuse.
I'd not buy another. The battery runs out too quickly and a spare is stupid money.
I'd still buy a Dremel, just not a battery one.
Can't you wire the switch up to be permanently closed, then put another switch inline with the power cord, maybe a foot pedal?
- DefTrap
- Has thanked: 1838 times
- Been thanked: 1468 times
I had a Lidl (mains) one that blew the motor as soon as I turned it on - I returned it, they didn't seem surprised.
I have another (really cheap, diy-store-brand) one that is ok, good enough, but has one of those motors that sounds like its about to break free.
- Has thanked: 602 times
- Been thanked: 4529 times
I've had a SIlverline one for years, as far as I know it still works, but I haven't used it for ages
I had the switch apart and cleaned all the contacts,but no joy. There's a tiny TRIAC which governs the speed controller,apparently this part commonly fails. The circuit board is miniscule,I can't see my soldering skills successfully replacing that part.KungFooBob wrote: Mon Apr 03, 2023 12:34 pm Can't you wire the switch up to be permanently closed, then put another switch inline with the power cord, maybe a foot pedal?
All the rest of the internals are like new,so in may be worthwhile rigging up a switch.
Had two Demels fail on me so i went for a Draper one . Been ok its a bit more powerful but i do miss the screwed on collet
for tightening the tool bits. Looks decent quality b, time will tell
asmethurst99
- Has thanked: 1333 times
- Been thanked: 486 times
I bought a von haus set
Like this but it was a lot cheaper last year
My child is using it to put new pickups in a guitar ( second hand Ibanez he bought)
I bought it to sort out some bodywork but still haven’t got round to it
- DefTrap
Proxxon is supposedly the best but I don't use these types of tools often enough to justify it.
- Mr Moofo
- Has thanked: 1926 times
- Been thanked: 1728 times
TBH , I have a dremel and also the Lidl one. The Lidl one is cordless
As mentioned above the Lidl one is a tad gutless - there is little torque to it. I bought it because of the power of the "Aisle of Dreams "
Oddly, the shaft is also a different size , meant the tool siren's really interchangeable
I have come to the conclusion for 99% of what I do. mains power wins - but then I am normally close enough to a mains socket.
- Yambo
- Has thanked: 512 times
- Been thanked: 1403 times
DefTrap wrote: Tue Apr 04, 2023 8:33 am Proxxon is supposedly the best but I don't use these types of tools often enough to justify it.
I have two Proxxon 'mini' drills. One has a stronger collar and collets instead of a chuck (the IBS/E) and I use it regularly as a mill in a Proxxon stand with an XY table. The other one is a lighter version (FBS 240/E)and I fitted a chuck to that one for a lot of general purpose work, small drilling, cutting etc. Both are getting on a bit now but are still in good order. My Dremel didn't last anywhere near as long before getting cranky.
I have quite a few Proxxon tools for model making and they're generally good. For small tools they are good - could be better in some instances but good.
- Has thanked: 20886 times
- Been thanked: 13705 times
I had a black & Decker one given to me and I gave it to the bin. Gutless thing couldn't cut pine! I've got a dremel but cant find the bastard thing and i need it to cut out the weld on the db killer on my Remus. Grrr!
I bit the bullet and ordered a new controller,but it's taking ages to arrive.
Demannu
- Has thanked: 65 times
- Been thanked: 1234 times
Like TBC, I have a silverline as well. It has seen some horrendous abuse over the years, and now the bearings/motor sound a bit rough, but still performs admirably.
After buying and fitting the new speed controller switch the Dremel still didn't work. I was on the verge of giving up when I decided to once again check the 4 wires coming of the windings on the stator. Visually,they all looked fine,but when I poked at them,one of the wires came away from it's connector. It's a very fine wire and not much length to work with to join another piece of wire,but I got there in the end and normal business was resumed. I think sometimes when you stop caring,then shit works again!
If you go to about 5.50 on the vid,you'll see an example of the same bother I had. Might save you a few quid.
- wull
- Has thanked: 979 times
- Been thanked: 1858 times
I can’t remember where I bought mine but it wasn’t that expensive and it’s been great, I’ll try and find out. It’s had a fair bit of use and is still going strong.
You did indeed,but when I first checked,all 4 wires looked to be well connected,but I should have checked more throughly. I accept the fine of £36 in wasted money.Screwdriver wrote: Tue Apr 25, 2023 11:21 pm Well, I could have told you that.
No, wait! I did!Screwdriver wrote: Mon Apr 03, 2023 1:22 pm There are some interesting possible "fixes" on YouTube, something to do with a tiny wire breaking in the circuitry but I haven't tried that yet.![]()
