Has thanked: 626 times
Been thanked: 4070 times
Bustaspoke wrote: Sat Mar 04, 2023 2:06 pm
Yorick wrote: Sat Mar 04, 2023 1:33 pm [
That's not SV650 engine.
I know,I own a SV650 :thumbup:
According to the description it's from a Suzuki Savage.I'm guessing it's the same motor as the DR650.
It looks like it's also running a belt final drive
The Savage had an engine all of its own, it's even more gutless than the DR650.
Has thanked: 15610 times
Been thanked: 9850 times
Has thanked: 532 times
Been thanked: 7238 times
I know nothing about it and it doesn't come up on a reverse image search...
kendo57
Has thanked: 241 times
Been thanked: 569 times
Post by kendo57 »
Mecum Auctions
rodbargee
Has thanked: 352 times
Been thanked: 969 times
Post by rodbargee »
Taipan wrote: Sun Mar 05, 2023 9:22 pm
this must be no 2 then
Has thanked: 216 times
Been thanked: 666 times
There is a world of difference betwixt a rotary and a radial......
Been thanked: 2501 times
David wrote: Sun Mar 19, 2023 8:04 am There is a world of difference betwixt a rotary and a radial......
So much so it's enough to make your head spin.
rodbargee
Post by rodbargee »
Interesting looking thing
At least that one wouldn't fall over when you blip the throttle......
Alan Millyard's Flying Millyard has an engine made from two barrels and pistons from a Pratt and Whitney radial aero engine. It's 5l, the pistons are huge!!
cheb wrote: Sun Mar 19, 2023 8:10 am
And the crank case (but not the crank...).
Has thanked: 9688 times
Been thanked: 9704 times
A 545 Kawaski 2 stroke four. £30k to you sir. :shock:
https://www.ebay.co.uk/itm/266104962020 ... R4Dq2P_fYQ
Has thanked: 10117 times
Been thanked: 6649 times
Skub wrote: Mon Mar 20, 2023 5:10 pm A 545 Kawaski 2 stroke four. £30k to you sir. :shock:
Offering a test ride when it's not run in yet?
David wrote: Mon Mar 20, 2023 7:59 am
Early rotaries,like Sopwith Camels, have the crank stationary and the cylinders spin, but someone worked out this was stupid, and on most rotary engines the crank spins and the cylinders are stationary.
Le_Fromage_Grande wrote: Mon Mar 20, 2023 8:22 pm
That's the difference between a rotary and a radial engine, the cylinder layout is the same.
The clue is in the name...Rotaries rotate...Radials spin in unseen ways...
Has thanked: 2611 times
Been thanked: 6015 times
Pfft, all engines hold on to the crank and spin the entire universe around, everyone knows that.
Has thanked: 264 times
Been thanked: 1242 times
It wasn’t stupid at the time. The rotary had a high power to weight ratio (compared to other contemporary engines) and didn’t vibrate the airframe to bits.
It was overtaken by developments in radial, inline and V-configuration engines.
rodbargee
Post by rodbargee »
