Since I last posted I've mainly been waiting for my local tame engineering shop to make up some parts for me and turn down some tube to the required o.d. Some excuse about the bloke who does this stuff having nearly severed all his fingers or somesuch...
Anyway the bloke came back (with all his fingers) and got to work making these for me. This is part of the drawing I supplied for the bits:
- Falco_yoke_wedges_detail.jpg (322.96 KiB) Viewed 420 times
Basically they are 15 degree wedges to level up the top deck of the Falco top yoke so I can mount the risers on a flat base. To fix them to the yoke I first sanded off the paint/anodising on the sloping surfaces, applied goodly amounts of JB Weld epoxy and then carefully placed the wedges on top of the epoxy, ensuring that the top face of the wedges were level with the central portion of the yoke. I'd rejected the idea of getting the pieces welded on, as there was a big risk of heat deformation. Once the JB Weld was firm to the touch I plonked the whole assembly on a radiator to speed up the cure.
After 24 hours it was ready for the next step, which was to drill 10mm holes for the risers. I only had one shot at this and it had to be right first time, so I fretted and fussed until I had A Plan. The underside of the yoke had been lightly milled to remove raised casting marks (part numbers, date of manufacture etc.) and provide a flat surface for the lock nuts to sit on. I eventually settled on a point for the first pilot hole and gingerly drilled from the underside with the work clamped down and a 4mm drill bit in the pillar drill. With the yoke unclamped, I was greatly relieved to find that the hole was nicely central and just where I wanted it. Result.
The next thing was to make sure the other hole lined up with the first one. For that reason I left the first hole at 4mm as it's much easier to judge where the other drilling centre should be. For the other hole I was drilling from the top side and eventually settled on a point, centre-punched it, clamped the yoke down and nervously started drilling, initially with a 4mm bit. I then moved through the sizes, finishing off with a 10mm bit. I suspect it's more through luck than judgement, but the holes look pretty well lined up to me. You be the judge...
- DSCF3581.JPG (904.8 KiB) Viewed 420 times
And here's a shot of the underside of the yoke. As you can see, the webbing on the underside seriously limits where you can mount the risers, but there was just enough space, courtesy of some careful milling. Next step is to drill out the initial hole to 10mm and see how (and if) the risers fit to the top yoke. Wish me luck...
- DSCF3584.JPG (821.33 KiB) Viewed 420 times
