Connecting a range cooker to the mains.
- Mr Moofo
- Has thanked: 1926 times
- Been thanked: 1728 times
I have just bought a new (to me) range cooker, which is dual fuel. I have a gas man coming to connect it on Thursday. With the electrical connection - and I allowed to do this myself , or does this have to be open by a qualified electrician?
- Has thanked: 2558 times
- Been thanked: 4169 times
Re: Connecting a range cooker to the mains.
If it's provision of a new circuit from the CU, then I believe this should be done by a qualified sparky. However if you feel you are competent and choose to do it yourself, I ain't tellin'...
If it's just connecting the appliance from an existing power point, I'm less sure. You (or whoever you employ) will need proper heat-rated cable to make the connection though.
- Mr Moofo
It would be using the cable that is in the current range cooker. Which is on a proper cooker power supply plug. It’s just as swap over
- Has thanked: 602 times
- Been thanked: 4529 times
Depends how confident you are working with a 30 amp supply, Couchy is the best person on here to ask.
- Been thanked: 9505 times
Do it yourself, the gas bit too.
It'll only be a bayonet fitting, all the gas man does it check it's not leaking after plugging it in.
You can do that, if you wake up dead, it's leaking. If your house doesn't explode it's fine.
- Has thanked: 781 times
- Been thanked: 1072 times
If you can wire a plug you can change a cooker supply.
The gas connection is even easier as it's just a push & twist plug.
In that case JFDI.Mr Moofo wrote: Tue Mar 14, 2023 1:23 pm It would be using the cable that is in the current range cooker. Which is on a proper cooker power supply plug. It’s just as swap over
- Mr Moofo
Can assume you have to turn it off at the mains - or does the bayonet have a valve on it?KungFooBob wrote: Tue Mar 14, 2023 1:33 pm Do it yourself, the gas bit too.
The socket is sprung valved, gas doesn't flow until you push the bayonet fitting in.Mr Moofo wrote: Tue Mar 14, 2023 2:19 pmCan assume you have to turn it off at the mains - or does the bayonet have a valve on it?KungFooBob wrote: Tue Mar 14, 2023 1:33 pm Do it yourself, the gas bit too.
Don't blame me if you die in a fireball.
- Mr Moofo
- Cousin Jack
- Has thanked: 3016 times
- Been thanked: 2528 times
If I hear a bang can I have the bike?
- Has thanked: 8048 times
- Been thanked: 5698 times
If it goes bang! You get it. If there's a bzzzzztaaaaaagh! I get it.
- Mr Moofo
Start to worry in a couple of hours when your canary dies.
- wheelnut
- Has thanked: 929 times
- Been thanked: 918 times
As has been said, you haven’t given enough info. Do you have a cooker socket to connect it to?Mr Moofo wrote: Tue Mar 14, 2023 11:29 am I have just bought a new (to me) range cooker, which is dual fuel. I have a gas man coming to connect it on Thursday. With the electrical connection - and I allowed to do this myself , or does this have to be open by a qualified electrician?
You sound unsure, so for what it would cost, get a man in.
- Mr Moofo
It would appear that my wife has banned me from touching it.
If the ban is permanent, I'd call that a win. You can never clean it or cook anything on it. It's the law...Mr Moofo wrote: Wed Mar 15, 2023 7:43 am It would appear that my wife has banned me from touching it.
- Mr Moofo
It was more the patronising " I would rather a professional does that"mangocrazy wrote: Wed Mar 15, 2023 9:26 amIf the ban is permanent, I'd call that a win. You can never clean it or cook anything on it. It's the law...Mr Moofo wrote: Wed Mar 15, 2023 7:43 am It would appear that my wife has banned me from touching it.![]()
Ask her to define professional, then ask how she will be checking their credentials.Mr Moofo wrote: Wed Mar 15, 2023 11:35 amIt was more the patronising " I would rather a professional does that"mangocrazy wrote: Wed Mar 15, 2023 9:26 amIf the ban is permanent, I'd call that a win. You can never clean it or cook anything on it. It's the law...Mr Moofo wrote: Wed Mar 15, 2023 7:43 am It would appear that my wife has banned me from touching it.![]()
For all she knows any Tom, Dick or Harry could be doing it, especially if she isn't there at the time.
