What to do with my old VW T4 van?
Demannu
- Has thanked: 65 times
- Been thanked: 1234 times
Re: What to do with my old VW T4 van?
My merc 316 is 20 in 3 months, uses a litre between oil changes (15k)
- Has thanked: 2558 times
- Been thanked: 4169 times
That's exceptional.Demannu wrote: Wed Feb 01, 2023 11:02 pm My merc 316 is 20 in 3 months, uses a litre between oil changes (15k)
- Has thanked: 1059 times
- Been thanked: 1646 times
Got a 220, 000 mile Toyota Hiace here, I won't say it doesnt use oil but I would say that it's not significant over a thousand miles.
It gets servived every six or so months cos thats dentists checkup day and I just take a day off for both. And I think fresh oil doesn't slip past the rings as much as oil thats past its best.
Hell, I think its still on its original clutch.
- DefTrap
- Has thanked: 1838 times
- Been thanked: 1468 times
My 210000 mile really crappy 406 uses hardly any oil, like literally a sip between oil changes. It's like those terrible old pair of shoes you have that look really frightful and you shouldn't really be seen dead in but somehow you just can't bear to throw them out.
Bigjawa
- Has thanked: 225 times
- Been thanked: 971 times
It's a 250k van, you could spend on the engine and the box or something else pack up shortly after, usually when one thing big goes a whole lot fails in quick succession.
You have to decide if it's worth the gamble.
- Felix
- Has thanked: 717 times
- Been thanked: 2045 times
Not air in the fuel lines? Partly clogged fuel filter or even drain as it could well have condensation water in it.Screwdriver wrote: Sat Mar 04, 2023 8:50 pm Stuck a new battery in the old bus and it starts with easy start but won’t keep going. Tipped in a gallon of petrol just in case but it still won’t start or run on petrol alone.
It’s a fuel injected V5 2.5 litre Audi thing, been stood for years so I assume something in the injectors is gummed up??
What should I try first to get it going? It’s there some sort of product I can pour into it to “free it up”?
