The Phoenix: Rusty Wrench Motorcycles Suzuki GSX 750
Has thanked: 5503 times
Been thanked: 12760 times
Has thanked: 1788 times
Been thanked: 1408 times
Re: The Phoenix: Rusty Wrench Motorcycles Suzuki GSX 750
I quite like that.
Seat's a slightly wrong angle
Has thanked: 532 times
Been thanked: 7226 times
I don't mind that (too much).
It either needs a front mudguard, or the mounts chopping off the forks and why have they made the levers in to prison shivs?
Has thanked: 15606 times
Been thanked: 9849 times
Dunno why, but i'm thinking that would be quite striking IRL?
Has thanked: 626 times
Been thanked: 4063 times
How I remember trying to get a GSX750 to run on pod filters, airbox went back on after endless fiddling with jets and air correctors.
Edit: just noticed it's got Teapot carbs, they're even harder to get running right in pods.
wull
Has thanked: 871 times
Been thanked: 1496 times
Post by wull »
Mr Moofo wrote: Mon Feb 20, 2023 9:39 pm I quite like that.
I think it’s more the tank that’s wrong making the seat angle look wrong when the seat flows with everything else, angle of the exhaust, engine etc.
I like it, would like to see the rear wheel on the ground to see how much the angles look with regards to the seat tank head etc.
Has thanked: 1446 times
Been thanked: 1331 times
Hope he doesn't need to adjust the settings on the forks....
Has thanked: 9682 times
Been thanked: 9702 times
Taint bad to look at,but there are quite a few practical issues if it's to be ridden.
G.P
Has thanked: 2113 times
Been thanked: 1310 times
Post by G.P »
What vintage of GSX is it? I had an '81 GSX750E. I recognise the engine but nothing else!
Druid
Has thanked: 277 times
Been thanked: 868 times
Post by Druid »
Le_Fromage_Grande wrote: Mon Feb 20, 2023 9:50 pm How I remember trying to get a GSX750 to run on pod filters, airbox went back on after endless fiddling with jets and air correctors.
I'm still trying to get my GS750 to run properly on pod filters. I've got enough jets to start a mail order business :(
I went through that process with my Z1. Bellmouths looked well trick. :roll:
I never got the thing running right despite having more jets than a race team. The last straw was my mate coming past on a Honda F1 when I was flat out.
The airbox made a swift return after that.
G.P wrote: Tue Feb 21, 2023 7:10 pm What vintage of GSX is it? I had an '81 GSX750E. I recognise the engine but nothing else!
83/84 ESD, but he's chopped around the rear end, now it's just a floater, rather than the full floater Suzuki wanted it to be.
Druid wrote: Tue Feb 21, 2023 7:45 pm
If it's still got the original slide Mikunis it's possible to do, you'll definitely need air correctors, speak to Chris at Grumpy 1260 for advice, don't be shocked by the swearing.
If it's got CVs off a later bike, good luck, I've never got CVs to work on pods.
You wouldn't think the crappy, tiny air boxes on 70s bikes would do much, but they obviously do.
Weirdly, I've never had any problems getting two strokes to run well on pod filters, not that the bikes ever went any quicker with them on.
Bigjawa
Has thanked: 223 times
Been thanked: 842 times
Post by Bigjawa »
Le_Fromage_Grande wrote: Tue Feb 21, 2023 9:57 pm
The only pods that work ok ish on the big oil boilers are the K&N double jobbies that are effectively 2 mini airboxes and even then it's a right faff.
Obviously going by the lack of mudguard that bike will never be ridden in the rain, if it even runs at all. The pods just look good.
DefTrap
Has thanked: 2269 times
Been thanked: 2086 times
Post by DefTrap »
I like the styling but not bothered about the GSX motor.
acrmnsm
Has thanked: 8 times
Been thanked: 3 times
Post by acrmnsm »
I likE the while thing, agreed about the levers but the rest looks great.
