New safety device ever riders needs ...
- Has thanked: 7525 times
- Been thanked: 5862 times
.. to consider ...
... 'why?'
https://www.motorcyclenews.com/news/new ... ty-device/
Sound plays an integral part in how you perceive your surroundings when you are out on the bike, but helmets and earplugs limit the amount of information you can gather. Now that could be about to change.
Tech firm Resonar have developed something called bat 8D auditory technology which does not amplify or modify surrounding sounds, but instead aims to restore your ability to hear them naturally.
The company’s Michel Wehe told MCN: “In our global race towards protective innovation and technological advancement, it seems we forgot about one of the most fundamental of senses.”
The tech is contained in a device that can be retro fitted onto any full or three-quarter face helmet and still limits excessive decibels while restoring awareness of so-called ‘deaf spots’ created by the helmet.
Much like blindspots, Resonar say these deaf spots fall outside the rider’s field of vision but when they are restored they allow the brain to build up a better picture of the surroundings and determine the direction and distance of passing vehicles with greater accuracy.
Additionally the bat 8D device increases a riders ‘proprioception’ – this is the ability of the brain to combine auditory and visual cues to create awareness of the body’s position and direction of travel in relation to other auditory info.
Resonar turned to the natural world, replicating aspects of the external part of the ear, known as the pinna, to funnel sounds.
Another feature of the Resonar bat 8D technology is an array of acoustic filters and materials that help control wind turbulence at speeds up to 50mph. It is claimed this allows the rider to focus on specific sounds generated by peripheral threats.
Internally, inspiration from nature continues with a patented set of an acoustic canals and a cone-shaped transducer, resembling the inner ear part of the human auditory system.
Designed to be tough, long-lasting, and waterproof, the Resonar device carries sounds directly through the helmet’s shell in a canal to the ear where it can once again be heard – rather than being muffled or cancelled.
The firm add that it is a battery free, cordless device with each helmet requiring a left and a right bat 8D unit to work correctly. They say it can also be used on the road by cyclists or on the track by motorcycle racers.
Resonar co-founder Felipe Morales, an acoustic engineer, was driven to invent the technology after losing a friend in an avoidable collision in 2014.
... 'why?'
- Has thanked: 7920 times
- Been thanked: 5583 times
Re: New safety device ever riders needs ...
I can see the logic. It always seems a poor compromise that in situations where you need all your faculties to be operating optimally, safety equipment that limits your vision, hearing and mobility/flexibility is the solution. ie stuff that protects when things go wrong is, potentially, going to help things to go wrong.
- Has thanked: 760 times
- Been thanked: 3172 times
Not battery powered so just picking up sounds and conducting them through the helmet shell, So will most likely have to be stuck on bloody well, may pose challenges for 22.06.
Using a comms systems is going to be tricky as it takes up that space on a helmet.
https://www.resonar.com/the-data/ , what data, just marketing guff.
I call bullshit.
so deafening above that?acoustic filters and materials that help control wind turbulence at speeds up to 50 mph
I call bullshit.
Precisely why I refuse to swathe myself in leather and "protectors" and continue with an open face helmet. I'm acutely aware of my vulnerability and ride accordingly. I don't need fancy expensive gadgets to help me.Count Steer wrote: Mon Feb 20, 2023 8:32 am I can see the logic. It always seems a poor compromise that in situations where you need all your faculties to be operating optimally, safety equipment that limits your vision, hearing and mobility/flexibility is the solution. ie stuff that protects when things go wrong is, potentially, going to help things to go wrong.
- Has thanked: 602 times
- Been thanked: 4525 times
Does this mean noisy pipes don't save lives?
