Our Hilux is not getting used now due to a contract change so it makes sense for it to go to a new home.
Huge build spec plus many changes sinsenweve had it to ensure it could get to where we needed it to.
Details below.
2014, ex-SSE special equipment vehicle built by QI Systems.
Rear cab unique to SSE.
Robinson Shutters roller doors
Internal racking - upper shelves both slide out for access
Custom sliding tray to access full length of bottom
Racking could easily be removed to give large area assuming sockets, etc are moved
Pair of sliding hydraulic ladder carriers
Pair of locking pipe tubes
Currently has an expedition alloy Safari Land Rover 110 rack 250kg capacity fitted but that’s going separately for sale unless negotiated
Full internal led lighting
Internal 12v and 4x 240v off inverter fitted in rear cab
External 12v on rear cab with magnetic plates for work light, etc
Superwinch 9200 winch. Has had new external switch and modular eye fitted
External remote with dual kill switches in bumper
Full set of amber led strobes
Full switch pack mounted above gear lever - strobes, front internal lights, rear internal lights, alarm override for rear cab microwave sensors.
Battery monitor system
Dual batteries
That’s as built for SSE complete with build/operation manual
Probably more I’ve forgotten
Since buying it:
Full Pedders updated suspension giving 50mm lift and 6 leaf updated rear springs (instead of 5)
Greasable linkages
Fully polybushed. (Milner) Gives slight NVH on front but can be dialled out
New upper arms with ball joints (Milner)
New lower arms with ball joints (Milner)
New front driveshafts
New internal and external hub seals
New uprated performance brake discs and ceramic pads (Milner)
Full service including diff oil changes and relocated breathers.
Mileage is just over 140k
Chassis is prepped with micaceous heavy build primer (same as we use on pylons/towers for which contract this was purchased)
Jungle steel rear bumper to remove oe plastic/steel combo with under run bar giving load/winch points and higher clearance
All 5 wheels are new Modular in OE size. Also still have the original wheels that could do with a refurb
All 5 tyres are brand new BF AT3
5 seats - rear bench lifts for loads .Was out of vehicle with custom shelf fitted for kit boxes for the entire time we’ve had it. Rears we’re never used by SSE either as their policy only allowed max 2 persons.
Extra set of rear grab handles
New dual rear camera system for towbar/rear mirror. Large dual input screen. Replaced installed system that was faulty. Cameras are independently pivotable for personal preference
Full vehicle specific heavy rubber matting
12v and usb sockets in front and twin usb in rear
Road legal front light bar fitted into grille
One scuff on rear ns quarter where I caught wall at home that’ll push out if you’re fussy
If you’re after a garage Queen to impress the school run mums then look elsewhere. This has been used for it’s intended purpose so has marks.
However it you want to impress said mums when their Evoque gets stuck then this is for you!
It’s a genuine and honest vehicle maintained regardless of cost as it had to be able to go with an hours notice.
Plenty more photos available on request
Price is £13,000 plus VAT
Toyota Hilux
- Has thanked: 25 times
- Been thanked: 54 times
Re: Toyota Hilux
Price drop to £11500 plus vat as need the space now.
Will come with a brand new MOT at sale time.
Can always look at a deal if you’re not vat registered
