Has thanked: 2609 times
Been thanked: 6012 times
Yambo wrote: Thu Aug 25, 2022 4:24 pm The question is why are the pads are staying in contact with the disc and getting hot and smelly?
Judicious use of the middle pedal probably. They're fine when Mrs D is a passenger for some reason.
Ant
Has thanked: 48 times
Been thanked: 227 times
Post by Ant »
Ant wrote: Thu Aug 25, 2022 3:32 pm If it stank of hot brakes, then isn't it likely an issue with the friction area not the hydraulics?
Smelly brake pads is just a symptom.
The question is why are the pads are staying in contact with the disc and getting hot and smelly? It's not many things that will cause that and they're all easy to check and rectify.
I see what you mean, the issue is that they may be stuck on all the time?
Yambo
Has thanked: 614 times
Been thanked: 1632 times
Post by Yambo »
Ant wrote: Fri Aug 26, 2022 4:55 pm
Basically yes. The piston may be seized in the caliper, or may be slightly offset in the caliper. The piston's rubber seal could be fucked - they flex a bit when the brake is applied and then re-assert themselves when the brake is released to just ease the pads away from the disc. If it's a single piston set-up then the equalising arrangement may be seized etc.
The disc may be warped so that the brake pads are coming into contact on each wheel revolution, not stuck on but enough contact to cause excess wear, heating and smell. Discs may be past their wear limit allowing the pistons to protrude too far out of the caliper where they can become offset.
Brakes are pretty basic (unless you're going to make them from scratch and calculate master and slave cylinder pressures/movement etc), bits are easily replaced etc. The one thing that most people like me don't have is the sucking of teeth technique and "Well it's brakes, innit. Ain't gonna be cheap darlin'" dialogue.
Has thanked: 1003 times
Been thanked: 1722 times
Strong is my charging foo.
Has thanked: 626 times
Been thanked: 4063 times
Bought a C reg Escort RS Turbo today
Has thanked: 532 times
Been thanked: 7217 times
Le_Fromage_Grande wrote: Sat Aug 27, 2022 9:36 pm Bought a C reg Escort RS Turbo today
But this one is loads cheaper.
https://www.pistonheads.com/buy/listing ... 8t8Bsaqol4
Has thanked: 579 times
Been thanked: 2289 times
2 x
1 x
And here endeth CFL's & incandescent lamps for this house
wheelnut
Has thanked: 939 times
Been thanked: 965 times
Post by wheelnut »
Pics please
Potter
Has thanked: 2216 times
Been thanked: 4610 times
Post by Potter »
I've been looking at them on the FB Ford groups, I'd quite like one but I wondered if they'd be as much hassle as all my other old things (Boat, bikes, etc).
It'll be interesting to see what your experience is, do a thread.
Has thanked: 1773 times
Been thanked: 1109 times
Potter wrote: Sun Aug 28, 2022 4:28 am
Princess Di's one sold for £650k, I think he means that one.
He didn't really buy an Escort.
He bough this Cortina instead.
https://www.ebay.co.uk/itm/394211828507
Potter
Post by Potter »
KungFooBob wrote: Sun Aug 28, 2022 9:10 am He didn't really buy an Escort.
I saw that as well, that's so council it's genuinely brilliant.
To pull off the full image you need grey sweat pants, builders tools in the back and a fat bird in leggings.
Has thanked: 15604 times
Been thanked: 9848 times
I was recommended Skechers Archfit trainers for upcoming rehab/physio, so I got a pair, and they are definitely on my pleasing purchase list!
Has thanked: 776 times
Been thanked: 4514 times
Taipan wrote: Fri Sep 09, 2022 3:28 pm I was recommended Skechers Archfit trainers for upcoming rehab/physio, so I got a pair, and they are definitely on my pleasing purchase list!
Funny enough, I was talking to somebody the other day and I mentioned that every time I see someone wearing Sketchers I couldn't help but notice they're always old people.
Congrats on the grandad pumps, Ol' Timer. :thumbup:
Has thanked: 10113 times
Been thanked: 6649 times
gremlin wrote: Fri Sep 09, 2022 7:39 pm
Says the man who brought his comfy slippers when you visited our villa :obscene-birdiedoublered:
The further you venture into your 50s, the more function overtakes fashion... :D
Has thanked: 16255 times
Been thanked: 3745 times
Taipan wrote: Sat Sep 10, 2022 12:39 am
TBF, I started wearing Sketchers in my late 30's. Haven't been able to afford them for years, so maybe I"m getting younger!! LOL
(I did look up the Archlift trainers and nearly had heart failure at the price!! Haven't even paid that for a decent pair of stilettos!!! - 85€ here, the Sketchers!!0
Has thanked: 1304 times
Been thanked: 1188 times
Post by slowsider »
:wtf:
MrLongbeard wrote: Sat Sep 10, 2022 2:14 pm ImagePXL_20220910_131039016 by MrLongbeard, on Flickr
Good shout. :thumbup:
