Not quite sure what to do with it yet. Originally I thought a Walter Wolf rep but every man and his dog has done one. So maybe a road legal track bike as it already has an after market front fairing.
Ideas?
That's what the clutch is for.KungFooBob wrote: Thu Aug 25, 2022 2:03 pm I had a Mk3 Gamma, it seized solid at an indicated 90mph in the fast lane of the M18.
Left a very long skidmark...
In your pants!KungFooBob wrote: Thu Aug 25, 2022 2:03 pm I had a Mk3 Gamma, it seized solid at an indicated 90mph in the fast lane of the M18.
I set them up, you knock out of the parkTarmacsurfer wrote: Thu Aug 25, 2022 2:05 pmIn your pants!KungFooBob wrote: Thu Aug 25, 2022 2:03 pm I had a Mk3 Gamma, it seized solid at an indicated 90mph in the fast lane of the M18.
Prepare to spend a lot of money
You'd need to love it considering that lot.Le_Fromage_Grande wrote: Thu Aug 25, 2022 2:49 pmPrepare to spend a lot of money
More seriously
1. Decide if you're going to keep the Gamma engine or spend £3K on a YPVS 350 engine and associated carb, exhausts and electrics
2. Assuming you keep the Gamma engine, make sure it has a spark, the cdi and coils are hideously unreliable on Suzuki two strokes of the 80s when they get old - a bad earth can make them fry the cdi and coil.
3. You've got a spark, take the top end of the engine apart and see how bad it is.
4. If the top end is rusty, so will the crank.
5. Check the frame and swingarm for cracks
6. Work out how much everything is going to cost before you start, double your estimated cost and be prepared to spend more.
Good luck
Indeed, because you'll never get back what you spend on it if you do it so you'd want to ride it.Skub wrote: Thu Aug 25, 2022 3:13 pmYou'd need to love it considering that lot.Le_Fromage_Grande wrote: Thu Aug 25, 2022 2:49 pmPrepare to spend a lot of money
More seriously
Good luck![]()
@Le_Fromage_Grande You are such a little ray of sunshine, you must be an absolute joy to live withLe_Fromage_Grande wrote: Thu Aug 25, 2022 2:49 pmPrepare to spend a lot of money
More seriously
Good luck
How the feck did you fit on one of them, i tried one round Knockhill and nearly ended up binning it a few times as my knees and elbows kept getting in each others way as the bike is tiny and you are taller than me i thinkKungFooBob wrote: Thu Aug 25, 2022 2:03 pm I had a Mk3 Gamma, it seized solid at an indicated 90mph in the fast lane of the M18.
That's a fair point, most of the non running bikes have been fit only for breaking if they didn't run.Potter wrote: Fri Aug 26, 2022 4:21 am I'd hold off a bit before I threw some petrol in and started it, I've done that and ended up with a seized bike and scored barrels.
Even a sticky piston ring will knacker you up sooner or later. I lost the dowel out of my piston, the ring spun around and got stuck in a transfer port and gouged a massive chunk out, which resulted in a knackered cylinder.
If it's a keeper (and not a do-er upper and sell quickly) then personally I'd get the head and cylinders off, send to Grampian motors for a measure and new pistons or rebore as required. This early work could save a lot of pain later and even if it wasn't actually buggered you'll still know that now you're good for 10k miles.
Check the crank - IME unless it looks knackered and there is obvious play, then it's probably ok.
Taking the cylinders off is so easy that it's not worth not doing, IYSWIM.
Whilst that's being done you can check the frame, if you're not sure then Maidstone Motoliner can advise you on that.
And whilst that's being done I'd junk the cdi, coils, whatever, and associated crap and fit an aftermarket system, like an ignitech, they're so much more reliable and you get a tiny flywheel so it spins up faster. Check the loom over and make sure you have continuity everywhere, old looms get stress breaks in them sometimes, I just literally bell it out from one end to the other to make sure it's all connected.
There isn't really much else to go wrong other than the obvious running gear that just needs TLC, new seals, etc.
Alternatively you could do what I did with my LC. I was reasonably certain that the engine needed a rebuild, but I wanted a bit of fun first, so I fired it up anyway and rode it until it broke, then rebuilt it. Although I know that LC parts are very easy to come by and even cylinders can easily be relined, etc.
