The M Endurance chain
- Been thanked: 9495 times
https://www.press.bmwgroup.com/global/a ... anguage=en
BMW have re-invented the chain. It doesn't need any lube and will never need any adjustment... yeah right!
I guess they had to do something with their reputation of final drive failure on the shafties.
Re: The M Endurance chain
I have a car with the N14 engine, it has the same problems as the N47Nobby wrote: Fri Aug 28, 2020 6:51 pm A chain that BMW says will last forever ?
Tell that to owners of their N47 engined cars.
- MingtheMerciless
- Has thanked: 3644 times
- Been thanked: 2502 times
I have some Snake Oil for sale and some gold/niobium/dysprosium HDMI leads for ultimate picture quality as well if your interested.
- Been thanked: 2727 times
If it doesn't need lubricating, won't wear out and won't need adjusting why are there adjustment carriers on the swinging arm in the picture?
Interesting concept though, I wonder how much, if any, improvement on normal chains it will be.
It's a £100 option on the S1000XR/S.cheb wrote: Fri Aug 28, 2020 7:17 pm If it doesn't need lubricate, won't wear out and therefore won't need adjusting why are the adjustment carriers on the swinging arm in the picture?
If you don't pay the extra £100, you'll need those adjusters.
- Has thanked: 778 times
- Been thanked: 3216 times
I also wondered what the effect of not using lube would have on the sprockets.
- Has thanked: 2908 times
- Been thanked: 1678 times
- Contact:
Unless you do silly miles (and I used to as a courier
) the sprockets wear out mostly because the chain stretches and no longer fits neatly in the 'valleys' of the teeth but rides up the side - that's what creates the 'breaking wave' effect on a very worn sprocket.
The main problem with X ring chains is the X ring deteriorating and letting the sealed-in grease escape - then the internal faces wear very rapidly. If these synthetic diamond-coated wearing surfaces were really that hard and friction free, they wouldn't need the grease, nor the X rings.
Lutin
- Has thanked: 368 times
- Been thanked: 383 times
Might have been easier, and cheaper, to make the chains enclosed. Though that might have ruined the look they were after for their bikes.
- Has thanked: 12605 times
- Been thanked: 8536 times
When I was a kid, chains were made from spaghetti.
Modern chains are much better. All my GSXR1000s lived on track, thrashed many times harder than any road bike. But only needed adjusting every few thousand miles .
I only lubed it when I fit a new tyre which was around 750 miles.
Bigjawa
- Has thanked: 225 times
- Been thanked: 969 times
The chain on my Bandit is older than 4 of my kids. It's been on the bike 15 years and really hasn't been adjusted much, I remember I bought it for my GSXR so it was stupidly expensive but it was worth every penny.Yorick wrote: Fri Aug 28, 2020 11:02 pm When I was a kid, chains were made from spaghetti.
