£11.95 for 90 minutes work,that's about £7.97 per hour. Sound reasonable?
Nice try. If I'd known it would take that long I'd have made charitable donations and run down the credit before switching and saved myself the hassle. As it was, I was stuck with it. I'd already spent the time by the time I realised I would have to spend the time.
The cost to you would be substantially more than that. And that's with mate's rates.
Adverts on the radio, telling us all about their broadband, broadband this, broadband what........but that's the question, broadband what? What is it that they're selling with a bandwidth which is broad?
Oh. Another. Athletics is my 2nd fave sports behind bike racing.
CBA to watch all coverage of the World Athletic championships so watch the 9:30 highlights.
Straight away some dozey tart says summat like one UK athlete gets a podium.
gremlin wrote: Mon Jul 25, 2022 11:37 am
This covid malarkey. Test started showing negative over the weekend. Great. Even started feeling better.
Today I've got a stonking headache, cough back again, all bunged up and, just to top it off, lost my sense of smell and taste. Test still negative.
Just fuck off, covid. Getting on my fucking nerves now.
One of my customers and her sister got it at Christmas. Both in there 80's and while the sister was in bed for two days my customer only had the sniffles however. On the bright side covid has all but rid her hay fever. Only a slight runny nose when the pollen count is high so its not all bad
Silicone sealant, I bloody hate the stuff and I'm shite at using it. Not helped by the "chequer plate" tiles I was having to seal against.
MingtheMerciless wrote: Mon Jul 25, 2022 6:49 pm
Dont cut the nozzle flat cut an an angle for better finish.
Also once applied spray with glass cleaner type spray and them do the finger wipe, shit don't stick then....
All I can say is that whatever your level of expertise you will get better results with Fugi than without. I would also admit to having used masking tape with it on the odd occasion.
mangocrazy wrote: Tue Jul 26, 2022 12:07 am
Yorick wrote: Thu Jul 14, 2022 11:50 am
Ordered standard 46.3mm bearings which Pen's nephew brought over. They are for the wheels on our heavy steel gate.
Wheel came off easily but had to smash the old wheel bearing out. Then I found that the new bearings were only 42mm. Bollox.
I had to bash the old broken shell back in and a few ball bearings so that the wheel will turn. Thankfully the gate still slides, albeit a bit clonky.
The bearing finally collapsed today. No shops have anything similar
So I bodged a wooden bush. Lots of oil and it slides nicely. 2 collets fit inside for the bolt to slide on. Not the wood itself.
Was quite proud of myself
Really? We're not even going to discuss the type of wood used? Oak might last for a bit I spose (it doesn't look like oak) If its pine I reckon it'll last til tomorrow.
That said - I glued the engine on my 406 about 40 thousand miles ago. All the keyboard-experts laughed ....
DefTrap wrote: Wed Jul 27, 2022 4:45 pm
It was an offcut of the Riga wood that they built our pergola from.
