POE switch / injectors
Has thanked: 146 times
Been thanked: 498 times
Post by Silly Car »
I need to power up at least 5 possibly 6 cameras via injectors or a switch with the following constraints:
4 cameras are wired back to a single place so I’m thinking a minimum of a 4 + 1 POE switch here
1 camera (possibly 2) are wired back to another location so I’m thinking a normal gigabit / 10/100 switch with 1 / 2 POE injector but I’m assuming each injector will need a separate 240v feed. Cost wise, might I be better with just another POE switch?
Cheers
Has thanked: 542 times
Been thanked: 7599 times
Re: POE switch / injectors
Tp-link 5 port PoE switches are cheap as chips and work well enough.
Injectors are ok if you have a three pin socket somewhere near by, but Switches give you more options.
Post by Silly Car »
Cheers, I’m guessing one unmanaged switch is pretty much the same as any other?
TP link seem to be around £25 each for a 5 port switch
Has thanked: 609 times
Been thanked: 4133 times
Silly Car wrote: Wed Jul 20, 2022 4:17 pm Cheers, I’m guessing one unmanaged switch is pretty much the same as any other?
Yep, they're all shit. Joking aside, the only things to check is back plane speed and port speed, I doubt if any unmanaged switch has a published backplane speed
Greenman
Has thanked: 209 times
Been thanked: 403 times
Post by Greenman »
Le_Fromage_Grande wrote: Wed Jul 20, 2022 4:37 pm
I'm sure that as long as the switch has POE ports he will be fine, it's just a house setup! The cheaper POE switches are designed for just this scenario are they not?
I would try and wire back everything to 1 central POE switch if you can. POE Injectors are a pain to hide cables in houses and take up your power sockets!
wheelnut
Has thanked: 911 times
Been thanked: 1010 times
Post by wheelnut »
Just check that the max wattage of the switch will drive the cameras ok.
