How to modify wall end to protect car from damage?
Asian Boss
Has thanked: 384 times
Been thanked: 522 times
Post by Asian Boss »
There's a small wall alongside my parking space. I have to park close to it if I want to be able to get my bike out of the garage.
Yesterday I went too close and scraped the car on the edge of the wall (d'oh!), see photo.
Any suggestions as what I can fix to the wall to prevent a repeat?
I was thinking Gripfill a 3/4 piece of pipe insulation on there. Maybe that's a bit of a bodge. Can anyone think of a better solution? I think it only really needs to cover the top 6 inches or so, of the side my car is on.
car wall.PNG (1.27 MiB) Viewed 872 times
Been thanked: 2721 times
Re: How to modify wall end to protect car from damage?
Old car tyres, hung down on ropes like a fishing boat.
Asian Boss
An interesting idea.
I think the problem is the front end of the wall, not the long flat side.
I still need to get the car close to the wall, tyres might be too wide.
Also it's visible from people's houses so can't have too great a visual impact.
Pool noodles?
Loads and loads and loads of old wine bottle corks?
Knock the wall down and rebuild it with sponges?
Buy a monster truck so any body work is higher than the wall?
Learn to park and look where you going?
Difficult to imagine anything that's hard enough to do the job,yet soft enough not to mark the car paintwork.
https://www.kingfisherdirect.co.uk/impa ... ll-buffers
Has thanked: 781 times
Been thanked: 1068 times
How about chamfering the corner of the wall?
Asian Boss
Skub wrote: Thu Jul 07, 2022 5:56 pm Difficult to imagine anything that's hard enough to do the job,yet soft enough not to mark the car paintwork.
A good point. I do go on very gently so wondered if I'd hear the squeak of insulation foam.
Cars often also parked in the street make it a tricky approach and I have to sort of three point it in on almost full lock.
I guess another option is to not park on the drive.
I will move house which will solve the the issue but that could be months or years away.
Has thanked: 8007 times
Been thanked: 5665 times
The pipe insulation should do the trick, open it out and stick it on the corner.
You'd be better off reversing in, obvs....but you'd have to climb out the other side. :D
Has thanked: 1080 times
Been thanked: 1010 times
Post by slowsider »
ChrisW wrote: Thu Jul 07, 2022 6:07 pm How about chamfering the corner of the wall?
He appears to be working on that ;)
Has thanked: 2844 times
Been thanked: 3495 times
A smaller car is the only answer. You could fix a length of plastic top to bottom on your side, but catching that would still be a problem. 🤷🏻‍♂️
Has thanked: 2839 times
Been thanked: 1599 times
You need one of those Citroen Cactus things :thumbup:
Post by slowsider »
v8-powered wrote: Thu Jul 07, 2022 7:25 pm You need one of those Citroen Cactus things :thumbup:
The one with the pricks on the inside? :D
Has thanked: 20807 times
Been thanked: 13612 times
My Mum had a ridiculously narrow garage and was always worried about chipping the doors when opening them or scraping on a pillar. I screwed some 2x1 roofing batons to the wall at the required height.
Been thanked: 4527 times
Why not just drive with a bit more care?
Is there room for a mirror next to the garage door above the wall? Not sure if it would work but even if you can't see right down the side of the car it might make it more obvious if you are slightly off line
Greenman
Has thanked: 148 times
Been thanked: 323 times
Post by Greenman »
Have you considered a trip to specsavers? :thumbup:
rodbargee
Has thanked: 397 times
Been thanked: 1114 times
Post by rodbargee »
I have a bit of plasterboard at the end of my garage to run the Alpina up against as I have only an inch or two to spare if you no more nails it to the wall You'd have to protect it from the weather that might help as the plaster wouldnt catch it as badly as the bricks seemed to have done not perfect buT that going to cost you 350-500 to fix. plasterboard's V cheap
Duct tape inflated balloons to the wall and when you get too close you'll hear them pop.
I wish this was my idea, but sadly I've stolen it from Viz
maccecht
Has thanked: 25 times
Been thanked: 167 times
Post by maccecht »
Screw a timber rail to the concrete as a bump stop if you feel the wheels hit it you know you are off line. Stop reverse and try again.
