When the lack of charging facilities at the site starts to impact on the value of the properties I predict that a solution will be found.Cousin Jack wrote: Mon May 09, 2022 8:07 pmNor will it help me, my parking space is remote from the house and getting a cable from my meter to the space would involve PP ( I live in a listed building, in a conservation area inside a world heritage site), wayleaves from 4 people and 1 company, as well as costing a fortune. Charging at home is not a viable option.Mussels wrote: Mon May 09, 2022 5:12 pm So there will be fewer people using charging points resulting in a smaller queue for them.
I get the thinking but in a city or town with Victorian terraces and flats that won't count for much.
- Has thanked: 8007 times
- Been thanked: 5665 times
- Has thanked: 7585 times
- Been thanked: 5913 times
And the cable probably wouldn't run from individual houses, it would be one main connection at the nearest point to the parking. Probably. Perhaps. Maybe. Just an idea.Count Steer wrote: Tue May 10, 2022 8:23 amWhen the lack of charging facilities at the site starts to impact on the value of the properties I predict that a solution will be found.Cousin Jack wrote: Mon May 09, 2022 8:07 pmNor will it help me, my parking space is remote from the house and getting a cable from my meter to the space would involve PP ( I live in a listed building, in a conservation area inside a world heritage site), wayleaves from 4 people and 1 company, as well as costing a fortune. Charging at home is not a viable option.Mussels wrote: Mon May 09, 2022 5:12 pm So there will be fewer people using charging points resulting in a smaller queue for them.
Yeah. The freeholder will probably stick a charger in the old stable or somesuch and the leaseholders get a chargecard/key card each. Stick a few p per kWh on to pay for it. When the leaseholders all want Teslas it'll happen.Horse wrote: Tue May 10, 2022 8:51 amAnd the cable probably wouldn't run from individual houses, it would be one main connection at the nearest point to the parking. Probably. Perhaps. Maybe. Just an idea.Count Steer wrote: Tue May 10, 2022 8:23 amWhen the lack of charging facilities at the site starts to impact on the value of the properties I predict that a solution will be found.Cousin Jack wrote: Mon May 09, 2022 8:07 pm
- Has thanked: 777 times
- Been thanked: 3208 times
Couchy
- Has thanked: 360 times
- Been thanked: 2246 times
That existing install is piss poor and dangerous. Done to the lowest price which is the story all over with domestic work. It’ll prob be a boil in the bag spark working for a local builders.
There’s many reasons we don’t do domestic and this is one of them
Seems the auditors that follow later for grant purposes ain't much better;Couchy wrote: Wed May 11, 2022 6:05 pm Done to the lowest price which is the story all over with domestic work. It’ll prob be a boil in the bag spark working for a local builders.
And now I'm going to take myself outside and give myself a proper talking to about watching video's about sparkies.
Couchy
He’s a prick, one as he’s called artisan electrics and two as he’s no idea he’s wrong. The codes they’ve used are done because not labelling something correctly can cause electric shock if someone is working on the system. He’s making out it’s a conspiracy to cover his own arse. Typical domestic sparky thinks he knows it all.MrLongbeard wrote: Wed May 11, 2022 7:10 pmSeems the auditors that follow later for grant purposes ain't much better;Couchy wrote: Wed May 11, 2022 6:05 pm Done to the lowest price which is the story all over with domestic work. It’ll prob be a boil in the bag spark working for a local builders.
I'd watch that video but he'd probably try and bill me for it.
- MingtheMerciless
- Has thanked: 3633 times
- Been thanked: 2495 times
At work we are looking to switch the maintenance staff vans to predominantly EV’s so they are investigating installing the charging infrastructure.
According to the Surveyor/electricians that came to the trial site for meetings the DNO’s are beginning to get a bit twitchy about domestic chargers as they are causing some very uneven phase loading at night.
For those that don’t know, electricity is supplied over the network in 3 phases (used to be known as red/yellow/blue) that’s 3 lots of AC out of phase by 120 degrees, domestic properties then get fed one phase and the neutral, so you might find in a street that some of the houses run on different phases (which is why you should never try to link electricity from different houses). The idea being that all the load is spread evenly across all three phases with no one phase taking a lot more load than the other two.
What they are finding with EV chargers is Sod’s law that people with them end up being on the same phase in a street so the night time load on the network starts getting unbalanced.
The other issue is older houses (like mine) have a 70 year old cable from the street designed when houses maybe had a TV and a kettle, fridge etc, maybe a cooker as well. Now we’ve got all our IT, electric showers, hot tub heaters and other goodies increasing the load and then you dump a 7KW charger on as well. So the DNO’s now have to be informed if you’re installing a 7KW charger and will state if you need a throttable one so as not to overload anything.
Reading between the lines I can see domestic chargers being held up until the DNO’s beef up their infrastructure to cope with the uneven loading and then also the general increase in load across the network (yes most of the night load will I suspect be within capacity already but I suspect there will still be charging during the day (shift workers, oh I forgot to charge it last night etc) which will be new additional load.
Balancing I can see being a huge issue, ironically one which having loads of batteries plugged in to the grid can help with.
Its not by accident that I've invested a chunk of my pension into firms who deal with grid storage and power systems
Overall capacity though, I'm not so sure. The national grid have already said that if everyone in the UK switched to an EV tomorrow total demand would still be less than the UK historic peak was (in about 2010). Since then UK electricity demand has been dropping steadily due to savings elsewhere, introducing EVs nationwide wouldn't even bring us back up to the highest demand ever.
- MingtheMerciless
Is that lost industrial load? It’s the local networks supplying housing estates that I think may have the capacity issue, not the “Grid” as a whole.
Is this all of the posh houses having EV owners, on one phase, and nasty cheap polluters on the others?MingtheMerciless wrote: Thu May 12, 2022 8:21 am According to the Surveyor/electricians that came to the trial site for meetings the DNO’s are beginning to get a bit twitchy about domestic chargers as they are causing some very uneven phase loading at night.
As mentioned in the linked first domestic charger video, smart charging may be internet- connected, so potentially remotely switchable to reduce total demand at any one time (or £charge accordingly).
Hoss stable built in 1933. We have (now both disconnected) original 1930s metal electricity conduits and gas plumbing in the walls for lighting.
But we probably are in the lower supply level from the street, as you mention.
Had a 30s place with all the electric run in screwed conduit. It made rewiring an absolute doddle.Horse wrote: Thu May 12, 2022 8:52 amIs this all of the posh houses having EV owners, on one phase, and nasty cheap polluters on the others?MingtheMerciless wrote: Thu May 12, 2022 8:21 am According to the Surveyor/electricians that came to the trial site for meetings the DNO’s are beginning to get a bit twitchy about domestic chargers as they are causing some very uneven phase loading at night.
Re: all this Internet connected meters etc, is it just me that thinks the end of civilisation won't be a virus or aliens? All it will need is for the Internet to go off.
Not ours - it was buried in the (horsehair reinforcedCount Steer wrote: Thu May 12, 2022 8:59 am
Had a 30s place with all the electric run in screwed conduit. It made rewiring an absolute doddle.![]()
- Cousin Jack
- Has thanked: 2983 times
- Been thanked: 2515 times
So, yet another reason to wait for the infrastructure. Not only will you have difficulty finding a public charger, and need to wait for ages to fully charge, but the holy grail of overnight domestic charging may turn out to be a poisoned chalice too.MingtheMerciless wrote: Thu May 12, 2022 8:21 am
Reading between the lines I can see domestic chargers being held up until the DNO’s beef up their infrastructure to cope with the uneven loading, and then also the general increase in load across the network (yes most of the night load will I suspect be within capacity already but I suspect there will still be charging during the day (shift workers, oh I forgot to charge it last night etc) which will be new additional load.
A car charger is what...7kW?
That's like having your kettle and your iron on at the same time pretty much. Obviously you don't run them both simultaneously for hours at a time, but you also don't fret about turning them on.
Ours was buried in the walls/under the floorboards...they just pulled new cable through it.Horse wrote: Thu May 12, 2022 9:06 amNot ours - it was buried in the (horsehair reinforcedCount Steer wrote: Thu May 12, 2022 8:59 am
) plaster.
Wouldn't have helped where we wanted new wall lights
- Has thanked: 781 times
- Been thanked: 1068 times
I've heard that a few times but it doesn't answer the question as we don't know how much generating capacity has reduced since 2010, I'd expect investment has reduced in line with demand.Mr. Dazzle wrote: Thu May 12, 2022 8:31 am Balancing I can see being a huge issue, ironically one which having loads of batteries plugged in to the grid can help with.
Both poor and rich people have kettles so averages say poor person is boiling a cuppa at the same time as rich person, if all the poor people had their kettles taken away and rich people boiled theirs at the same time then there would be the same problem.Mr. Dazzle wrote: Thu May 12, 2022 9:31 am A car charger is what...7kW?
- Has thanked: 1059 times
- Been thanked: 1643 times
This comparrison is worth a watch, its US based so the numbers don't work out the same but our petrol costs a hell of a lot more so if anything our numbers are even more stacked in favour of the lecky car.
