Your oil appears to have dissolved the teeth on your sprocket!!
Cobrra Nemo 2 Chain Oiler ?
- Has thanked: 5954 times
- Been thanked: 3572 times
Re: Cobrra Nemo 2 Chain Oiler ?
Wow now you mention itdosruedas wrote: Fri Apr 08, 2022 6:22 pmYour oil appears to have dissolved the teeth on your sprocket!!
- Has thanked: 20859 times
- Been thanked: 13679 times
Will do. Haven't even looked if there is anywhere yet. I don't want to run it down from the bars that's for sure. TBH it's so easy to lube it on the centre stand, I'm not even sure I'll bother fitting it?
