Whyte T-130 Size Large. 2016. Decent condition, well looked after mechanically. Large. £750
Bear with me a little on this one in terms of spec... I'm not collecting it until later. It's slightly different to this picture, being more standard than this one (this pic has Hope Wheels and Fox 34s),
Image2022-03-02_05-28-54 by Steve Weeks, on Flickr
Basically this used to be mine... i bought it a while ago and in the end I sold it to my boss. He's now bought my G-170 and i've taken this in part-ex.
I recently had it in my garage for some bearings and replaced the chainstay bearings, 2 linkage bearings and a suspension bushing. The brakes were bled and the gears serviced with new cable along with setting up.
It also has a Rockshox Reverb stealth dropper post, which isn't wonderful, but i'll give it a bit of a service, it's just a little sticky compared to a new one.
Other than that, it's a pretty decent bike.... But either the Sworks or the T-130 has to be sold really, we can't have 5 bikes. So whichever goes first, goes first.
I'll do a full spec list later, but it's 10 speed Shimano SLX, Shimano SLX brakes, 130mm front and rear and standard Whyte finishing kit. It's got a few marks, battle scars and touch ups... but it's an exceptional bike for the money and won trail bike of the year on it's release in 2016.
I've owned this Wyhte T130 since new, although a mate did have it for 2 years on loan.
I've used it plenty, serviced it plenty and it's a cracking bike. It's just had a brand new dropper post fitted as the Reverb had failed. It's recently had a full service with new frame bearings, new bottom bracket, new headset. Gear cables have been replaced and the brakes have been bled. New pads in the rear brakes just to finish things off nicely.
it's got some marks, but they're only paint marks. Other than that it's in full working order. Both tyres are set up Tubeless and hold air perfectly.
Frame 6061 T6 SCR Aluminium Front Triangle with Tapered Head Tube and Intergrip integrated seat clamp system, alloy symmetrical SCR rear Triangle, 142mm dropouts
Fork RockShox Revelation 27.5”, RL, 130mm Travel, Fast Black coating, Tapered steerer and 15mm Maxle
Rear Shock RockShox Monarch Debonair, RT3, Fast Black coating, Adjustable Rebound and Compression
Headset FSA No. 57E Orbit ZS, 1.5” Cartridge Sealed Lower Bearing and 1 1/8” Upper Bearing Rear Hub Alloy, Double Sealed Cartridge Bearing
Hub, Boost 12mm X 142mm Through Axle, 32 Hole Front Hub Alloy, Double Sealed Cartridge Bearing Hub
Hub 15mm X 100mm, 32 Hole
Spokes WTB 2.0mm, Black Sandvik Stainless Steel Spokes, Brass Nipples
Rims WTB Asym i23 27.5” Rims with TCS System, Tubeless Ready
Tyre WTB Trail Boss, TCS Light Fast Rolling 27.5” X 2.25”, Folding
Shift Levers Shimano SLX, 10 Speed
Front Derailleur N/A
Rear Derailleur, Shimano SLX 10 Speed
Cassette SRAM PG-1070 10-42,
10 Speed Chain SRAM PC-1030,
10 Speed Crankset Shimano Hollowtech 2, 30T Raceface chainring narrow wide,
Bottom Bracket Shimano threaded, 73mm
Seatpost Brand X Ascend, 30.9
Seat Whyte Custom dual density, triple panel design
Bar Renthal Fatbar carbon , 25mm Rise, 760mm Wide
Stem Whyte Gravity Stem,50mm L
Grips Whyte Lock-on
Front Brakes Shimano SLX, 180mm Rotor, Internal Routing
Rear Brakes SLX, 160mm Rotor, Internal Routing Brake
Levers Shimano SLX
Pedals None
Re: Whyte T-130 Size Large. 2016. Decent condition, well looked after mechanically. Large. £750
price dropped to £750 as i have bought him a new bike so no use for it now.
SOLD.
