INCOMING, Happy 50th to me.... Yeah, it's a Yamaha... it's the easy option.
- Has thanked: 5450 times
- Been thanked: 13085 times
Re: INCOMING, Happy 50th to me.... Yeah, it's a Yamaha... it's the easy option.
Add to that, for what they are, they're very very expensive. They're £3000+ more than the same MT07
- Been thanked: 4124 times
That'd put me off, cheaper to change the riding position of the MT
- Has thanked: 15952 times
- Been thanked: 10243 times
I never got on with the XT660R I had and moved it on shortly after buying it. It felt like a completely different bike to the XT660X.weeksy wrote: ↑Thu Mar 24, 2022 1:28 pmIt's a decent point...I've not ridden many things with funny sized front wheels.Le_Fromage_Grande wrote: ↑Thu Mar 24, 2022 1:23 pm What about the Tenere 700, surely it has the riding position and engine you want?
I'm not against the looks too much. But the only one i can really think of close was @G.P Triumph 800 which I absolutely HATED and couldn't get round a single corner when i rode it.
Thanks to @Taipan i now have the taller seat fitted... but now the rain and winter have appeared again so sod knows when it'll get used.
2022-04-05_02-10-00 by Steve Weeks, on Flickr
Well that was so nearly a winner... The seat height position is actually brilliant and it really does mean i can move my foot easier into 'race' position.
The downside is that to do so, i need to push my arse too far back on the seat for where i want it, otherwise there's a transition / ridge that i don't like where it goes from lower>raised. So you end up either sitting near the tank with your arse on the ridge, or behind the ridge but that's almost like you're going down Mugello straight and trying to get yourself into a racing aero crouch.
- Has thanked: 9827 times
- Been thanked: 10145 times
What about a shock which allows you to raise the rear ride height?
Nah, wouldn't want to mess with the handling etc matey.
- Has thanked: 10263 times
- Been thanked: 6886 times
MotoGP stylee height adjuster. Really impress your pals
LOL i don't have any who ride bikes but are not on here
The ones on here are not going to be impressed by an MT07 unless i put a 1299 engine in it.
It's worth considering. A few mils can make a huge difference,both in handling and comfort.
I had an Ohlins on a ZX9R with ride height adjustment. I just fiddled until it was a slappy bastard,then backed it off a bit for a sweet turning bike.
It might feel odd to start with, but was it not worth sticking with it to see if you got used to it?
I quite like the standard seat.... so not really no.... the comfort thing isn't a massive issue, certainly not a deal breaker. But was worth a try.
- Has thanked: 4360 times
- Been thanked: 2851 times
Have you tried shortening your legs?
i could cut off my feet, but it'll make changing gear really hard. !
I'd already thought of that, Jigsaw and some gorilla glue. Take a few mm out the thigh area
Already had that done with my cock to make it 6" shorterYorick wrote: ↑Tue Apr 05, 2022 3:30 pm This in reverse..
https://www.dailymail.co.uk/health/arti ... tched.html
- Has thanked: 1264 times
- Been thanked: 1188 times
Cant you fit a dropper post?
With my FZR400 I stuck a 20mm foam race seat on top of the standard seat.
Yes, but, well, I'm me. There's correct, there's wrong, there's nothing other than that.Le_Fromage_Grande wrote: ↑Tue Apr 05, 2022 9:56 pm With my FZR400 I stuck a 20mm foam race seat on top of the standard seat.
Hence, I rebought the swing arm today.
It's got to be right
