- Has thanked: 261 times
- Been thanked: 1269 times
- rodbargee
- Has thanked: 353 times
- Been thanked: 980 times
Pierre Terblanche’s concept motorcycle the Mike Hailwood Evoluzione took everyone by surprise and was the undoubted star of the show. None were more surprised than the Italian press, so often party to inside information at the factory. “Over the summer I left Bologna and completed this project in England,” Terblanche says. “Ever since Mike Hailwood won at the Isle of Man in 1978 I have wanted to build my own interpretation of those magnificent NCR racers.”
Terblanche went to AKA design in Hitchin, north of London. Here, over an eleven-week period, he worked with a three-dimensional model on the computer and constructed a full size clay model. The idea behind the Evoluzione was to recreate the NCR racers of the late 1970s. While using an air-cooled two-valve fuel injected 900 Supersport engine as a basis, the engine was tidied externally through the use of sump covers to hide the oil cooler and lines, with the ignition coils on the camshaft bearing supports on the cylinder heads. The engine had polished engine cases reminiscent of the earlier “round-case” Ducatis, but apart from the clutch was that of a standard 900 Supersport. The clutch was one of the more special components on the bike. Weighing a mere 800 grams, it was a slipper design with three plates and a diaphragm spring by Poggipolini and Zornik.
The tubular steel frame was a special construction by the Dutch company Troll, placing the engine as far forward in the frame as possible while retaining the same offset as the normal 900 Supersport with a 23 ½ degree steering head angle. Though a twin shock swingarm in the style of the original Hailwood Replica was initially considered, this was discarded for a tubular single-sided swingarm with Öhlins 125 Grand Prix shock absorber, and modern 996 fork. The wheelbase is still a very short 1,420mm. Wheels were Marvic, the rear being 6.00x17 inches with a 200/50x17 inch tire. To minimise unsprung weight a single 305mm disc was used at the front. The disc was a product of Mislav Zornik and constructed of Selcom, a carbon silesium combination. Using only a single front disc enabled the other brake calliper mount to be machined off the fork and a single-sided stainless steel bracket installed to locate the front mudguard.
One of the more advanced features was the one-piece fairing and fuel tank. Designed to keep as much weight on the front wheel as possible, this unit was a nylon polymer, rotationally moulded and heated while rotated. The rear indicators were in the exhausts, with gases exiting through a Super Trapp-style exit. The Valeo headlight too was quite small, being only 80mm in diameter. Other unique features were the voice-activated ignition system and television rear vision camera.
The Mike Hailwood Evoluzione also represented a new path for Ducati. As Terblanche says, “This is really an extension of the Harley factory custom idea. Here we take basically a standard bike and alter it in such a way as to create a completely new expression. My idea was to get away from complexity and carbon-fibre. I also wanted to capture the feel of the racing bike, that is why it is elemental, with very clean lines.” Pierre Terblanche breaks the motorcycle into four distinct elements. The engine, frame, wheels, and bodywork. “Thus it becomes a custom,” he says, “and every component looks good.”
- Has thanked: 16014 times
- Been thanked: 10265 times
- Has thanked: 2636 times
- Been thanked: 1523 times
I think it's missing the bombsight...
- Has thanked: 1264 times
- Been thanked: 1188 times
I see where you're coming from
- Has thanked: 7827 times
- Been thanked: 2532 times
At first glance I thought that '///HPN' sticker actually read "Taipin".
- Has thanked: 540 times
- Been thanked: 7550 times
Ok, it's not a bike, but click the link and look at the under bonnet pic, see if it makes you smile like I did...
https://www.ebay.co.uk/itm/154919629669 ... Sw0GliJ6ti
- Has thanked: 2556 times
- Been thanked: 6266 times
That looks like the electric start version.
There were Bond models that required you to get your leg in there to kickstart the engine.
- Been thanked: 4127 times
Great paint job (imho)
One of the best looking 'storms I've seen.
