Cobrra Nemo 2 Chain Oiler ?
- Has thanked: 20859 times
- Been thanked: 13679 times
Was going to order up a Tutoro chain oiler for the X-adv, but happened across the Cobrra Nemo 2 Chain Oiler. Not even sure how it works, but looks nicely made? Anyone got one, use done, seen one?
https://www.cobrra.co.uk/nemo-2/
Tarmacsurfer
- Has thanked: 100 times
- Been thanked: 111 times
Re: Cobrra Nemo 2 Chain Oiler ?
I've fitted a Loobman to my last couple of bikes.
You have to remember to push a button every so often and the instructions are a bit wacky but for 22 quid it's great.
http://www.loobman.co.uk/
I used to be a big fan of Scottoiler,but I find these days,cleaning and oiling the chain every so often works just as well,plus it's not as messy as an oiler.
I think the one in the link is a manual operated jobbie,give the lid a turn every so often. If you are riding all year around in all weathers,then an oiler is probably beneficial. Otherwise,the odd clean and lube does the job. I use chainsaw oil.
- Has thanked: 2556 times
- Been thanked: 4167 times
I'd be interested to see a bit more about the boring bits that actually make it work, like the business end that delivers oil to the chain. A link to a product video would be handy.
As Skub says, you fill it, then pressurise it by turning the lid. You can use almost any oil too.mangocrazy wrote: Tue Mar 22, 2022 8:54 pm I'd be interested to see a bit more about the boring bits that actually make it work, like the business end that delivers oil to the chain. A link to a product video would be handy.
https://www.webbikeworld.com/cobrra-nem ... er-review/
The one minor drawback I can see over (for example) a Scottoiler is that the tube run from the bars to the rear sprocket is longer and more visible than the run from an (often concealed) reservoir to the sprocket. There's also the question how you'd mount the reservoir if your bike has clip-ons or risers rather than a traditional handlebar. But on the plus side you don't need to dick about finding a vacuum feed (or equivalent). I've been running Scottoilers on every bike I've owned since the late '80s so I'm used to that way of working. I doubt I'd switch to a Nemo2 system, but it's good that there are multiple options for people to keep their chains lubed.
No idea why, but I've never had any luck with scottoilers? I've used a Loobman with some success and the same for a Tutoro, but both of those have been bit of pain with temp changes and oil viscosity, hence why this Cobrra intrigues me. I think I may take a punt, but then the X-ADv has a centre stand which makes lubing chain super simple...
bernieeccles
- Been thanked: 8 times
https://bengting.aliexpress.com/store/1 ... 52d4pw1mY4
Exactly the same, much lower price.
No need to mount on handlebars as you can mount it anywhere. I have one on the inside of the left rear foot peg of my Ninja 1000sx which mirrors where the rear brake reservoir is on the opposite side.
I can just reach down and give it a twist, even when moving.
Nice one, thanks. I take it you like the way it works etc?bernieeccles wrote: Thu Mar 24, 2022 8:16 pm https://bengting.aliexpress.com/store/1 ... 52d4pw1mY4
bernieeccles
I have used a Scottoiler in the past and still have a nearly new one, but I just did not fancy hacking into the Ninja 1000 to find a vacuum feed. This one is neat and easy to apply oil when I want, plus I just use a mixture of gear oil and engine oil which I always seem to have. Price wise the cost of my oil is buttons against the genuine Scottoiler stuff.
The one thing I did use off the Scottoiler was the fitting for the "injector" pipe because I thought it looked nicer!
For £17 delivered, you can't go wrong IMO !
Hmmm - that could be a useful option for the LC. No vacuum take off that I'm aware of, so an AliExpress £17 cheapie looks very appealing.bernieeccles wrote: Thu Mar 24, 2022 8:16 pm https://bengting.aliexpress.com/store/1 ... 52d4pw1mY4
- dern
- Has thanked: 1183 times
- Been thanked: 2277 times
- Has thanked: 2908 times
- Been thanked: 1678 times
- Contact:
Ta, I've been looking at the Cobrra ever since my Oxford electronic oiler packed up, but thinking it was far too expensive. I've just bought one on Aliexpress. Only thing is delivery is billed at 6 weeks. Still, it's a HUGE saving for what's obviously the same thing.bernieeccles wrote: Thu Mar 24, 2022 8:16 pm https://bengting.aliexpress.com/store/1 ... 52d4pw1mY4
- Has thanked: 8040 times
- Been thanked: 5694 times
Nice one @bernieeccles and welcome!
2 posts, 3 happy chain-oilers.
Likewise. Mine arrived today. Looks good.
bernieeccles
Davie lad
- Has thanked: 193 times
- Been thanked: 238 times
I also bought one, it looks good for the price, but I’m struggling to see how it fits to my Royal Enfield Interceptor swing arm , I may have to get an additional bracket…
- Has thanked: 779 times
- Been thanked: 3216 times
