Agree, do not want sprung slats.
mattresses
- irie
- Has thanked: 1482 times
- Been thanked: 411 times
Re: mattresses
- Has thanked: 6196 times
- Been thanked: 5088 times
Re: mattresses
We bought an Emma, back in August. There are various discounts available, IIRC we got 30% as Filly is in one of the professions that they support (sic).
It's fine, post-op I was able to sleep comfortably even without a pillow, it adapted so well. Definitely more comfortable than the previous pocket sprung, with goose / down topper.
We turn it (rotate) occasionally, but not flip, as it's layered and has a 'top' layer.
Re: mattresses
As long as I get to sleep before the missus starts snoring I can sleep on anything.
But if I did have a recommendation it would be the best matress I'd every come across.
...and I've come across a few.
- Has thanked: 498 times
- Been thanked: 650 times
Re: mattresses
I did the research, decided which was best for me, went to a bed / mattress shop and lay on it... it wasn't all that.
I tried loads in the shop, found one which felt perfect and bought it.
Pocket sprung, no foam or topper bollocks, extra firm, under a bag from memory.
I paid twenty quid extra for the delivery to be to the bedroom and seeing the two guys sweating getting it up to the top floor I was glad I did.
- Has thanked: 1264 times
- Been thanked: 1188 times
Re: mattresses
You paid twenty quid to see two guys sweating in your bedroom. Hope you have the hat..
- Has thanked: 15962 times
- Been thanked: 10248 times
Re: mattresses
We got an Emma mattress recently. First thought was we got the wrong one as it's too thin and makes the bed a lot lower? Sit on the bed and you almost crush the mattress to the slats. But, lay on the bed and it's very supportive, weirdly so?? Took a bit of getting used to as I didn't think its was doing anything, but then you realise its sort of filled in any gaps and supports you totally? The best bit is I don't get the pressure points I was with my Sealy pocket sprung, so I'm a convert without a shadow of a doubt. I used to wake up through discomfort but I don't anymore. I now just lay there awake and feeling cosseted, where as with my old mattress waking up, meant getting up! That said, I'd still rather it was thicker and will see if they do a thicker one and if so, this one can go into the spare room.
- Has thanked: 657 times
- Been thanked: 362 times
Re: mattresses
We went to dreams, they have a techy bed thing you lie on and it measures you (and your Mrs) and recommends the best mattresses for you. Seemed honest as well because it didn't just recommend the expensive ones.
We got a Hyde and Sleep raspberry; multi spring doodah with memory foam topper... Both sleeping much better and my back issues have reduced significantly.
Re: mattresses
I think our Emma Mattresses memory foam has got dementia! The two areas where we sleep forget to go back to normal, well at least compared to the middle bit that doesn't get laid on? Maybe we're too heavy for the thin 150mm version, so I've just ordered a 250mm medium firm variant!
- Cousin Jack
- Has thanked: 2553 times
- Been thanked: 2287 times
Re: mattresses
A long while back I was persuaded by the missus to buy a Tempur memory-foam mattress at HUGE expense. It has been OK (we have had it for about 7 years now) but it was (and still is) eye-wateringly expensive. It may even be the best in the world, but I am still not convinced it was worth that much.
- Has thanked: 2552 times
- Been thanked: 6256 times
Re: mattresses
Their NASA thing is such bollox.Cousin Jack wrote: ↑Thu Jan 20, 2022 7:34 pm It may even be the best in the world, but I am still not convinced it was worth that much.
Well, I'm sure they could well be the only mattress company approved by NASA, but come on now, you'd have to be putting in some real effort to make a mattress which is uncomfortable in zero G. I imagine NASA actually approve it 'cause it's light, has good fire properties or something like that.
Re: mattresses
At the heart of each mattress and pillow we create is our iconic TEMPUR® Material, born from NASA technology. In the late 60s, NASA scientists invented a unique new material, later called memory foam, to cushion pilots against the rigors of test flight.
we’re the only mattress and pillow officially recognised by NASA for improving quality of life.
Re: mattresses
Ha ha - that rather turns the tables doesn't it?Horse wrote: ↑Thu Jan 20, 2022 8:02 pm At the heart of each mattress and pillow we create is our iconic TEMPUR® Material, born from NASA technology. In the late 60s, NASA scientists invented a unique new material, later called memory foam, to cushion pilots against the rigors of test flight.
"Our mattresses are so good NASA approved them"
Or.
"We took this technology from NASA"
- Has thanked: 7819 times
- Been thanked: 2529 times
Re: mattresses
Yup. That happened to the one i bought, after only about 6 months. Hate the things.Taipan wrote: ↑Thu Jan 20, 2022 7:20 pm I think our Emma Mattresses memory foam has got dementia! The two areas where we sleep forget to go back to normal, well at least compared to the middle bit that doesn't get laid on? Maybe we're too heavy for the thin 150mm version, so I've just ordered a 250mm medium firm variant!
Re: mattresses
Hmm, kinda worrying! But I don't have any hip problems since switching from a pocket sprung to one of these. I'll see how it goes...Rockburner wrote: ↑Thu Jan 20, 2022 8:12 pmYup. That happened to the one i bought, after only about 6 months. Hate the things.Taipan wrote: ↑Thu Jan 20, 2022 7:20 pm I think our Emma Mattresses memory foam has got dementia! The two areas where we sleep forget to go back to normal, well at least compared to the middle bit that doesn't get laid on? Maybe we're too heavy for the thin 150mm version, so I've just ordered a 250mm medium firm variant!
- Mr Moofo
- Has thanked: 1829 times
- Been thanked: 1469 times
Re: mattresses
About 25 years ago, on discovering the wife was asthmatic, we bought a very expensive latex low allergy mattress. It was bloody horrible. They insulate and become like a thermonuclear device ! The next 15 years were spent completely soaked in sweat in the summer. Dreadful thing.WelshDragon wrote: ↑Tue Jul 28, 2020 11:14 am
Anyway wouldn't have anything other than a latex mattress now.
When it went, I was able to sleep normally again !
- Has thanked: 144 times
- Been thanked: 497 times
Re: mattresses
We bought a Nectar mattress at huge expense around 18 months ago, we bought a replacement mattress a couple of weeks ago due to the sagging where we sleep and the huge hump in the middle. It is being repurposed onto a spare bed.Rockburner wrote: ↑Thu Jan 20, 2022 8:12 pmYup. That happened to the one i bought, after only about 6 months. Hate the things.Taipan wrote: ↑Thu Jan 20, 2022 7:20 pm I think our Emma Mattresses memory foam has got dementia! The two areas where we sleep forget to go back to normal, well at least compared to the middle bit that doesn't get laid on? Maybe we're too heavy for the thin 150mm version, so I've just ordered a 250mm medium firm variant!
We’ve said never again to a mattress that turns up squeezed into a box, the replacement is sprung with a pillow top.
Re: mattresses
Modern memory foam mattresses will have some sort ventilation built-in.Mr Moofo wrote: ↑Thu Jan 20, 2022 8:44 pmAbout 25 years ago we bought a very expensive latex low allergy mattress. It was bloody horrible. They insulate and become like a thermonuclear device !WelshDragon wrote: ↑Tue Jul 28, 2020 11:14 am
We bought an Emma (expensive? Never buy one full price, they usually have discounts of some sort, ours was 35% or 40% off) 18 months ago, wouldn't want to go back to springs.
- Has thanked: 838 times
- Been thanked: 1240 times
Re: mattresses
Odd, I bought a latex matress about 15 years ago because I wanted a cool matress and memory foam was known for being warm. Maybe the allergy stuff in yours stopped air circulating. I wouln't be without it now, the only problem I've had is moving it as it weighs about 60kg.Mr Moofo wrote: ↑Thu Jan 20, 2022 8:44 pmAbout 25 years ago, on discovering the wife was asthmatic, we bought a very expensive latex low allergy mattress. It was bloody horrible. They insulate and become like a thermonuclear device ! The next 15 years were spent completely soaked in sweat in the summer. Dreadful thing.WelshDragon wrote: ↑Tue Jul 28, 2020 11:14 am
- Has thanked: 6381 times
- Been thanked: 4761 times
Re: mattresses
Got a Tempur a few years ago, it wasn't cheap but there are more expensive traditional mattresses around. Don't like it. Wife does. It will stay compressed in places eg hip area after a while but recovers somewhat if given long enough ie 2 weeks holiday but then seems to compact faster. ie they lose resilience. Traditional next time and hang the expense.(probably not Harrison Spinks at £5k though ).Cousin Jack wrote: ↑Thu Jan 20, 2022 7:34 pm A long while back I was persuaded by the missus to buy a Tempur memory-foam mattress at HUGE expense. It has been OK (we have had it for about 7 years now) but it was (and still is) eye-wateringly expensive. It may even be the best in the world, but I am still not convinced it was worth that much.
Have had Dunlopillo (latex) previously and preferred to memory foam but they compress too. (Not cheap either cf memory foam).
