A mate of mine out in Oz, Laurie, goes by the business name of Suspension Smith and makes a living developing unusual two wheeled suspension ideas. One of his ongoing projects is combining linkage and telescopic forks for off road machines....
..and he's also built a downhill mountain bike with the same front end design...
Now, I've got no desire to emulate his front suspension design but how he's made the frame is of interest to me...
Laser cut aluminium side plates with bolted in headstock, bottom bracket, stand-offs etc.
I'm looking at building a long travel e-mtb d/hill bike, that can be pedalled to the top with Mr. Bosch doing the hard work, using the same basic same frame construction idea.
Bosch gen 4 motor, 29" front wheel, 27.5" rear. Triple crown 200mm travel forks, adjustable offset yokes, adjustable +/-3 degrees head angle with head stock inserts, +/-30mm reach adjustment moving the headstock fore and aft, long and slack geometry, high pivot rear suspension with an idler sprocket (think Commencal Supreme DH), 240mm rear travel, adjustable seat angle, bolt on rear dropouts to adjust chain stay length, no welding - all CNC and bolted together.
Maybe crash it through the Hope catalogue for some garish anodized gee-gaws.....
