So the boy came in yesterday saying "dropper post isn't returning right", basically it wasn't reaching max extension. I thought initally it was down to the post needing a little Fork Juice on it... but it wasn't to be.
He'd also complained about a stiff lever... which irritated me as i'd only just fitted the cable.... but admittedly it was one from the spares box and we fitted it under pressure so was maybe not given a squirt of lube first....
So i set about both. Cable was swapped (still a crap job that) and i worked out the pressure in his post was slightly low, so not giving it that final shove. Put some more pressure in and away we go. silky smooth and nice.
Next job was one of the easier ones. The presta valve core was a bit wonky and stiff, so replaced that with a new valve core.
I then picked up and moved the bike, to find the rear brake was rubbish, stupid soft at the lever. He runs his quite soft anyway but this was daft. Don't know how this never got mentioned y'day in post-ride chat. So a bleed was required... however, it's irrirated me for nearly a year that the rubber bung on the end of his hose was missing.
The one bottom right.. I already had several in spares, so decided to completely disconnect the hose and do a full bleed after fitting it. Anyway, not the toughest job, but it's done now.
The one thing i do wonder is, "do other parents go through this level of detail and spannering on their kids race bikes" ? Or am i just really fussy ? Or do they just let them ride it ? Or do they just give it to the LBS and say "make it perfect" I don't know really.. but i do seem to spend a fair bit of time tweaking his.
