BMW R50
BMW R50
Picked this up today , not mine but a friends which i offered to try and get running.
Its a 1956 R50 and has been sat in a damp shed since 1972 , so first job was to remove
spark plugs and squirt some penetrating oil into the cylinders. Will leave it over night
and then start cleaning the carbs tomorrow .
- Has thanked: 5455 times
- Been thanked: 13103 times
Re: BMW R50
There isn't one really, the guy who owns it is in his late 70's and i think he would like to ride it again.
He last rode it in 1972 , took it over to Europe and then laid it up when he got home. He obviously
has some fond memories of riding it.
If i can get it running ok then we will look at getting it to MOT standard but at the moment he doesn't
want to spend much on it.
- Has thanked: 6200 times
- Been thanked: 5090 times
Re: BMW R50
One thing to be wary of when you do get it running - and I was warned the same when given the key to one for a bimble - the forks don't dive under braking, so it's easy to squeeze harder because your brain isn't getting all of the usual cues. At which point the tyre lets go.
- Has thanked: 7822 times
- Been thanked: 2532 times
Re: BMW R50
Hah! Motorworks still do parts for them!
https://www.motorworks.co.uk/vlive/Shop ... NU=15&M=10
Excellent project, hope it come together!
Are you going to put up more pics?
- Has thanked: 9844 times
- Been thanked: 10156 times
Re: BMW R50
That was back when BMW actually had some build quality.
Lovely project,look forward to watching it progress.
Re: BMW R50
Not just do them, it says:Rockburner wrote: ↑Mon Jul 20, 2020 8:38 pm Hah! Motorworks still do parts for them!
"We are expanding our range of parts for these models"
Re: BMW R50
Cleaned the fuel system today , carbs , fuel tank , not too bad really better than i expected.
Tank is incredibly clean for a 60 year old
Carbs were mainly dirty on the outside
I put penetrating fluid down the bores and left overnight , then oil in the morning and turned it over.
I also put fresh engine oil in the engine. Felt much freer after a few kicks
Checked the points and wiring
Re: BMW R50
Ah the days of setting your ignition timing with a rolly up fag paper!
Re: BMW R50
Nah, tune a transistor radio to static. When the points open, you'll get a 'pop' on the radio.
Re: BMW R50
Olde Pharte.
Re: BMW R50
Oi! Non-smoker OF, if you don't mind
And anyway, it was a transistor radio, not valve or crystal set.
Re: BMW R50
Compression tested the cylinders , 110psi on both after a few kicks. Happy with that as it
only runs a 7.5 / 1 compression ratio.
So i need a spark now, ordered a new battery from Ebay then decided to read the manual
which i downloaded off the net. Should of read the manual first because i found out the bike
runs a magneto type ignition which runs separate from the electrical system.
So back to the bike and no spark, quick read on the internet and the Mag earths through the
ignition switch which can give problems with age. So i removed the headlight and disconnected
the Mag earth from the switch. Result , now i have a spark.
Carbs put back on , new plugs , some fuel and started kicking. A few kicks in and i get a small
ignition through the exhaust. Quick adjust on the throttle and more kicks then its alive.
Re: BMW R50
The tappets aren't too tight anyway!
- G.P
- Has thanked: 2029 times
- Been thanked: 1310 times
Re: BMW R50
Excellent! Really sturdy bikes, look aces with a single saddle and a little racj where the pillion perch is.
I'd be looking to modernise the electrical system for reliability sakes though.
Top job
Top job
Re: BMW R50
And is that a brief view of the hinged rear mudguard, to ease rear wheel removal?
Re: BMW R50
Worryingly i checked the tappets this morning and they were fine. I have removed the sump and cleaned
the filter hoping for better oil flow.
Yes correct
