Trust me the R6 is sorrier than the ZX...Unless you wanna swap, in which case it's a lovely project needs no work at all.
The Triumph
- Has thanked: 4359 times
- Been thanked: 2850 times
Re: The Triumph
- Has thanked: 5450 times
- Been thanked: 13085 times
Re: The Triumph
I'm brave, but not that brave to give up her ZX6 for a shonker R6...
- the_priest
- Has thanked: 1874 times
- Been thanked: 2170 times
Re: The Triumph
The reason for needing a new clutch cable...
- Been thanked: 7526 times
- the_priest
Re: The Triumph
Clutch cable now replaced and suddenly it is nice and smooth! That will make a nice difference when I do finally ride the bike again. Brake lines must be done first as the single line is too tight to risk riding and I need to clean up the mudguard. Require some black spray from Halfords I think.
- Has thanked: 15949 times
- Been thanked: 10243 times
Re: The Triumph
I broke the Tmax so could update that thread!
- the_priest
Re: The Triumph
Yup, plastic ones in the tank and they went "crack". So I've ordered two from Tom Parkers for the replacement.Mr. Dazzle wrote: ↑Thu Dec 02, 2021 8:57 am I remember mine being brittle and shit in about 2004 when the bike was only 7 years old.
cLCD100040V CPC PIPE THREAD - VALVED - MALE THREAD (THREAD SIZE: 1/4" BSPT - FUEL LINE BODY) £21.53 EACH EX VAT Delivery £8-95
- the_priest
Re: The Triumph
Plastic Triumph Quick Connectors. Pop! I've bought a fuel filter as well so when I change the lot over, it will also have a new filter. Should be simple enough right?
Metal Fittings on the fuel lines.
- the_priest
Re: The Triumph
Trying to get that broken quick release connector out is a real pain! The okay one came out reluctantly, but it came out in one piece. The broken bit is not shifting at all. I'll have to get it out piecemeal, Probably remove the whole pump and then work on it out of the tank.
- Has thanked: 2550 times
- Been thanked: 6244 times
Re: The Triumph
You'll need a gasket too then I think? It's been a while since i've been in there, but IIRC everything is bolted to a common metal plate which is turn makes a 'window' into the tank?
- the_priest
Re: The Triumph
Correct. I'll sort that in good time. There is not rush as I am not riding in this weather now! I've become a FWB in full! Besides, I'm not able to ride in robes, too flappy! I may do it once for a laugh though!
Re: The Triumph
On your way to combat the Zombie apocalypse, rat triumph and flapping robesthe_priest wrote: ↑Tue Dec 07, 2021 8:54 am Besides, I'm not able to ride in robes, too flappy! I may do it once for a laugh though!
- Screwdriver
- Has thanked: 256 times
- Been thanked: 740 times
Re: The Triumph
This is the most recent and relevant ULEZ thread. Rather than contribute to Saddo Khant pension scheme, I spunked SEVENTY FIVE quid on Yamaha to send me an A4 sheet of paper.
Like most bikes of this era, it did not need to specify the NOX emissions but they were way under the then current eurobollocks. So everybody knows this particular model has euro3 compliant NOX emissions (0.09 whiffs almost half the 0.15 waft required to duck under ULEZ stealth tax).
I still have to pay an outrageous amount for a piece of paper which will be IDENTICAL to the thousands of other Fazer Thous out there. My prize is the ability to drive literally across the road when you would have thought that if this is really about saving the environment, any one single application with proof of compliance should automatically apply to ALL models.
The kicker is of course, they'll probably change the requirements before I even ride the blasted thing...
- the_priest
Re: The Triumph
Count yourself blessed. The Dyno session for the Triumph cost previous owner £175 and he was only just into the ULEZ area!! Less than 1/4 of a mile too!
I have the fitting now, just need the PTFE tape and patience to remove the old broken plastic bits out of the thread. Awaiting the new fuel filter as well and a new fuel plate rubber gasket as the old one was totally knackered. In the bin!
Re: The Triumph
Is it really? It seems to be a thread about rebuilding a Triumph not one about spouting political bollox.
Re: The Triumph
I like the idea of quick release fuel lines if not the execution in Triumph's case. Trying to balance the fuel tank whilst attempting to force the fuel pipe over the barb isn't one of my favourite things.
- Has thanked: 599 times
- Been thanked: 2435 times
Re: The Triumph
The Triumph system ain't too bad once the fittings are metal, you can just jam and jab blindly until something clicks without much fear of damage
- Screwdriver
Re: The Triumph
Change the limit edit times then if you're just going to whinge.
Re: The Triumph
I'm not whinging. Just telling you to keep the political rubbish in the correct forum.Screwdriver wrote: ↑Tue Dec 07, 2021 8:24 pmChange the limit edit times then if you're just going to whinge.
You could have easily brought up the ulez without turning it into a soap box, I'd not have questioned it.
Anyway, back to the topic.
Re: The Triumph
I think the Triumph ones are mostly about the pressure, the quick releases element is a happy bonus. As above the fuel pump is inside the tank (actually immersed in the fuel IIRC) so the fuel comes out of the tank at several bar. If you had hoses with springs clips or wherever you'd run the risk of them blowing off.
