Tool purchases
maccecht
Has thanked: 25 times
Been thanked: 167 times
Re: Tool purchases
Post by maccecht »
Just got one of these surprisingly well made.
Has thanked: 3633 times
Been thanked: 2496 times
Re: Tool purchases
Not sure if this was the wisest buy, you'll find out tomorrow after I attempt to remove the rear calliper bolts from the naughty X-Trail.
Re: Tool purchases
If you use that on caliper bolts the next post will be "Drilling a broken caliper bolt"
Has thanked: 316 times
Been thanked: 1078 times
Re: Tool purchases
Post by Silly Car »
Hope you’ve got sufficient clearance, I regularly have to do the two spanner trick to get enough leverage to shift calliper bolts as I don’t have an impact gun and never seem to have enough room to get a breaker bar in.
Has thanked: 20811 times
Been thanked: 13614 times
Re: Tool purchases
I simply cannot imagine working on a vehicle without using one of these now. One of the best things I've ever bought. Removing the 19 x 8mm bolts from the Tmax engine casing was literally done in a minute or so. Fab things!
Re: Tool purchases
Taipan wrote: Mon Oct 25, 2021 3:42 pm I simply cannot imagine working on a vehicle without using one of these now. One of the best things I've ever bought. Removing the 19 x 8mm bolts from the Tmax engine casing was literally done in a minute or so. Fab things!
Yep. Every home should have one. :thumbup:
Has thanked: 8011 times
Been thanked: 5666 times
Re: Tool purchases
Ooh. Want. Is that the DTW700/701?
Q? Are standard sockets ok with them? According to the blurb you need to use impact grade sockets - never knew there was such a thing.
Been thanked: 9455 times
Re: Tool purchases
Aren't 'impact grade' the black ones in the tool box that no ones uses because the shiny ones are much nicer?
Re: Tool purchases
KungFooBob wrote: Mon Oct 25, 2021 4:09 pm Aren't 'impact grade' the black ones in the tool box that no ones uses because the shiny ones are much nicer?
Mine are all shiny ones. :(
Been thanked: 4527 times
Re: Tool purchases
Count Steer wrote: Mon Oct 25, 2021 4:18 pm
My impact ones are black, like Boris Johnson's soul.
Re: Tool purchases
Le_Fromage_Grande wrote: Mon Oct 25, 2021 4:24 pm
So I'd need to buy some more sockets? That's a :thumbup: and a :thumbdown:
:D
Re: Tool purchases
Count Steer wrote: Mon Oct 25, 2021 4:03 pm Q? Are standard sockets ok with them? According to the blurb you need to use impact grade sockets - never knew there was such a thing.
Standard sockets are fine,just squint a bit when you fire the trigger. :thumbup:
Has thanked: 2841 times
Been thanked: 1599 times
Re: Tool purchases
Skub wrote: Mon Oct 25, 2021 5:45 pm
I've seen impact sockets give up too, not a pretty sight. Heavy use though..
Re: Tool purchases
Dunno which one it is. I have 3 of them! 2 Fakitas and one genuine! :lol: Yes and impact drive should use impact sockets and I do with my 240v Clarke CEW1000 but with this, I've been using my Teng 1/4 drive sockets with a step down adaptor. I used it to take all the hinges out of some furniture I was breaking up. It just rattles out the screws better than a drill with a screwdriver bit in. No wonder all the trades use them. :thumbup:
Re: Tool purchases
Black and single hex? My life is almost complete...
Has thanked: 1059 times
Been thanked: 1643 times
Re: Tool purchases
Got this a while ago, think it was about fifteen quid secondhand.
Torque screwdriver.
Has thanked: 781 times
Been thanked: 1071 times
Re: Tool purchases
I always prefer impact sockets, they have six points rather than twelve so great for removing difficult nuts without mangling them.
Re: Tool purchases
Mussels wrote: Mon Oct 25, 2021 7:41 pm I always prefer impact sockets, they have six points rather than twelve so great for removing difficult nuts without mangling them.
Sometimes, you can get six point sockets with thin walls for tight spaces and impact sockets usually have pretty thick walls so not so good when its tight.
Although impact sockets for rattle guns.
derek badger
Has thanked: 1089 times
Been thanked: 1741 times
Re: Tool purchases
Post by derek badger »
Some imperial allen keys.
Re: Tool purchases
demographic wrote: Mon Oct 25, 2021 7:01 pm Got this a while ago, think it was about fifteen quid secondhand.
Torque screwdriver.
Just took a punt on three of these (untested) for £12.50!
1 x Red Torquemaster Standard: (8 ozf in - 36 lbf-in) (600 gmf cm - 40 kgf cm) (6 - 406 c N m).
1 x Red Torquemaster Standard: 8 oz-in to 36 lb-in. Left & Right Hand
1 x Green Torquemaster Minor: 3 oz-in to 12 lb-in.
