Trail braking - on the road?
Has thanked: 357 times
Been thanked: 919 times
As the title says - is it useful? I've always looked on it as a track technique for squeezing extra seconds, but does it have a place on the road? Matey below thinks so.
Do you, and if so, when?
https://www.google.com/url?sa=t&rct=j&q ... 1Vp3zS_iZe
Couchy
Has thanked: 360 times
Been thanked: 2246 times
Re: Trail braking - on the road?
Post by Couchy »
Braking while in a corner is essential on the road surely ? , not to the extent as you would on a track but still it’s needed
Has thanked: 12607 times
Been thanked: 8537 times
It's a useful thing to be able to do in an emergency.
What's trail braking, if it's braking while leant over, it used to be pretty normal when bikes had 18" front wheels, skinny tyres and weak brakes.
Has thanked: 2908 times
Been thanked: 1678 times
Wossname wrote: Sun Oct 24, 2021 11:19 am As the title says - is it useful? I've always looked on it as a track technique for squeezing extra seconds, but does it have a place on the road? Matey below thinks so.
Yes you should be able to do it on the road, and this video is probably the worst explanations of why. If you watch it, you'll see at least a couple of places the 'expert' rider cocks up and runs wide.
Guess what I'm talking about in my next scheduled webinar in the SURVIVAL SKILLS ONLINE TALK SERIES on WEDNESDAY 3 NOVEMBER?
'BRAKING THE CIRCLE'
will consider whether or not we should be BRAKING IN BENDS' - is it an 'avoid at all costs' manoeuvre, or essential skill?
Not every rider manages to slow down AND keep control braking in corners - it leads to far too many crashes.
From the author of the 'Science Of Being Seen' presentation, this LIVE WEBCAST looks at how braking and steering inputs can work together without overwhelming tyre grip. TICKETS ARE JUST £5. Link to the presentation will go out approximately 24 hours before the event.
BOOKING LINK http://thq.fyi/se/a6831b869ea8
I think I've always done it,if I'm having a bit of fun,I thought everyone did. Maybe it's just a matter of degree.
Skub wrote: Sun Oct 24, 2021 3:53 pm I think I've always done it,if I'm having a bit of fun,I thought everyone did. Maybe it's just a matter of degree.
Yup, always done it, thought everyone did.
singlesman
Has thanked: 227 times
Been thanked: 144 times
Post by singlesman »
Bloody hell! I don’t do it on the track never mind the road.
# feeling inadequate 😂
Hairybiker84
Has thanked: 69 times
Been thanked: 108 times
Post by Hairybiker84 »
KungFooBob wrote: Sun Oct 24, 2021 4:07 pm
Me too!
Bigyin
Has thanked: 1436 times
Been thanked: 2738 times
Post by Bigyin »
It’s also easier to do on those pesky telelever front ended BMW bikes ;)
Hairybiker84
Bigyin wrote: Sun Oct 24, 2021 4:32 pm It’s also easier to do on those pesky telelever front ended BMW bikes ;)
Oddly enough, it didn't seem to have much beneficial effect on mine - If you weren't careful there would be lots of clattery clunking from the back end as the rear suspension struggled (even more) to cope with the mass!
Funnily enough, it's only beneficial on certain corners.
Been thanked: 3504 times
Yes, if I'm going in a bit too quick.
Couchy
Post by Couchy »
So those that don’t brake in corners wtf do you do when you have to slow in a corner ?
Another thought, has everyone who has abs actually tried it out ? 80mph then grab the brakes till the bike stops ? It’s impressive especially in the wet, if you haven’t go try it don’t wait till you need to do it. Same applies if you haven’t got abs but less of the grab and wait for the abs to sort it out 🤣
Has thanked: 7621 times
Hairybiker84 wrote: Sun Oct 24, 2021 4:37 pm
Typically, braking affects the balance by increasing weight on the front.
Why, then, would the rear struggle?
Couchy wrote: Sun Oct 24, 2021 6:44 pm So those that don’t brake in corners wtf do you do when you have to slow in a corner ?
Isn't trail braking when you brake before the corner then continue it into the bend?
Braking in a corner, for example, is if there's an obstruction, Isn't it?
wull
Has thanked: 979 times
Been thanked: 1858 times
Post by wull »
Yorick wrote: Sun Oct 24, 2021 6:07 pm Funnily enough, it's only beneficial on certain corners.
It’s beneficial in all corners, if you’ve already loaded the front end by trailing the brake and then have to apply more brake because of an obstacle or whatever it may be then there is much less chance of the front locking up and washing away.
If you weren’t trailing the brake and then had to grab it for whatever reason the front will lock up much more easily.
But I personally don’t see the need for it on the road, I’m not saying I don’t do it and I suppose it’s how you ride on the road etc but at the end of the day you’ll do just fine without doing it.
On the track it’s a different story
This is a good video from Sylvain explaining it well.
wull
Post by wull »
Horse wrote: Sun Oct 24, 2021 6:49 pm
Trail braking is when you brake for the corner and then as you turn in start to reduce the brake pressure as you go round the corner or in track terms go towards the apex.
This method allows you to brake later so essentially you are at full throttle for longer, so when you turn in you are still reducing your speed towards the apex. Also, it allows the bike to turn in faster because the front end dives reducing the rake of the bikes geometry. Also, the front tyre will have a larger contact patch giving more front end grip.
Crash :thumbsup:
Sounds like braking for a corner and keeping the brakes on while leaning the bike, pretty much normal riding road or track 30 years ago, when I did motocross and Super Moto I braked all the way to the apex on tight corners.
