so more fettling on the xsr
Posted: Wed Sep 09, 2020 7:07 pm
In my quest for the perfect bike, i have turned my steely gaze toward the suspension of my baby.
It is well known that the XSR is too firm at the back and too soft at the front.
I had a zx6r shock (£23 ebay special) lurking around that the mt boys use, but i could not get it to fit on the xsr.
However a quick check found it to be the same length spring and pretty close in diameter, so out came the compressors and in a flurry of spanners the spring was swapped over and slapped back in the bike.
The front end has pretty unique springs so a compromise was required.
This was found in the way of some 9n/mm ohlins springs for a gsxr6 (£25 ebay haggle) and 2 x 40mm spacer from an R1 fork.
Still messing about with ride heights but most importantly the front no longer dives like jacques cousteau and the rear doesnt try and kick you about over the rough stuff.
